Page 28 of 33 FirstFirst ... 182627282930 ... LastLast
Results 271 to 280 of 321
Thread: Garett's ford maverick 1990,
  1. #271
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    What did you use to clean the carbonization inside the manifold?
    i used a sandblasting cabinet, then smoothed out the casting inside with die grinders and flap wheels.
    Jan 2015
    19 Post(s)
    where is the best place to get a UFI 250HP 12mm Pump from ?
  4. #273
    193 Post(s)
    Just go straight to UFI. . Worth considering a built 11mm tho reckon if I did it again that's the way I world go. .
  5. The Following User Says Thank You to Rossco For This Useful Post:
    garett (26th March 2023)
  6. #274
    465 Post(s)
    Yeah I reckon my 12mm is wasted too. 11mm would do the same as I am now but probably with less soot. Lol.
  7. #275
    Jan 2015
    19 Post(s)
    would the ufi200 pump be a good option ?
  8. #276
    Jan 2015
    19 Post(s)
    just ran a compression tester over it and 430 to 450 psi
  9. #277
    Jan 2015
    19 Post(s)
    well the front diff is on the bench... cant stand the bearing noise any longer. fitting the gu locking setup and replacing all the steering links and a few other things
  10. The Following 3 Users Say Thank You to garett For This Useful Post:
    BigRAWesty (12th April 2023), mudnut (11th April 2023), rusty_nail (11th April 2023)
  11. #278
    Jan 2015
    19 Post(s)
  12. The Following 4 Users Say Thank You to garett For This Useful Post:
    BrazilianY60 (18th April 2023), MB TD42 (19th April 2023), mudnut (16th April 2023), PeeBee (16th April 2023)
  13. #279
    Jan 2015
    19 Post(s)
    got a wheel alignment done, oh boy does it ride better now...
  14. The Following User Says Thank You to garett For This Useful Post:
    mudnut (18th April 2023)
  15. #280
    Apr 2021
    Brazil
    Like a train on tracks!
    What is this GU locking setup at the front you mention?
