Page 32 of 33 FirstFirst ... 2230313233 LastLast
Results 311 to 320 of 321
Thread: Garett's ford maverick 1990,
  1. #311
    194 Post(s)
    Plassy, its a mount frame for an intercooler coil
    Plasnart (30th March 2024)
    473 Post(s)
    “I am most worried about a front end collision and the strong lineal forward facing frame not heading upwards but unfortunately becoming a spear through to beloved little ones”
  5. #313
    194 Post(s)
    I dont think the frame size has enough column strength and the frame is not substantial enough to resist much MB, its a fairly flimsy configuration I think, looking at the mount location its in the center of the firewall with only a single 90 deg column, 25mm rhs - they should be OK I reckon. If anything it will fold up pretty easily I think.
  6. #314
    473 Post(s)
    Dearly hoping, thanks @PeeBee
  7. The Following User Says Thank You to MB For This Useful Post:
    PeeBee (30th March 2024)
  8. #315
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    the frame is less substantial then the bonnet and the engine block, am running some bracing under the joins, hopefully it lasts long enough so i can save up for a proper kit.
  9. The Following 2 Users Say Thank You to garett For This Useful Post:
    MB (1st April 2024), PeeBee (31st March 2024)
  10. #316
    Jan 2015
    19 Post(s)
    put coolant in it and fresh oil. replaced the filters, wired the cooling fan for the intercooler, painted the frame and made a exhaust manifold shield.
    just got to sort from the inter cooler to the manifold.. then do all the prestarts.
  11. The Following 3 Users Say Thank You to garett For This Useful Post:
    MB (9th April 2024), PeeBee (7th April 2024), Touses (7th April 2024)
  12. #317
    Jan 2015
    19 Post(s)
    i fired it up today.... need to sort a catch can.
    it idles a bit high.. 800 cold it used to be 600.
    at idle it got to 100 deg exhaust temp only ran it for 15 mins or so to bleed coolant etc.
  13. The Following 4 Users Say Thank You to garett For This Useful Post:
    Cremulator (14th April 2024), MB (13th April 2024), PeeBee (13th April 2024), Touses (14th April 2024)
  14. #318
    Jan 2015
    19 Post(s)
    well i took it for a trip around the block... manages to hit 500c at about 110 when i lift... got the alarm at 550c
    tops out at about 1.4 bar
    may need to get this thing tuned
  15. The Following 3 Users Say Thank You to garett For This Useful Post:
    MB (15th April 2024), PeeBee (14th April 2024), Touses (15th April 2024)
  16. #319
    Jan 2015
    19 Post(s)
    does anyone know anywhere in Adelaide that is good at tuning a td42 ?
  17. The Following User Says Thank You to garett For This Useful Post:
  18. #320
    Jan 2015
    19 Post(s)
    doing the rear bushes and one of the nuts picked up the thread.
    hopefully this stops it from pulling left under throttle.(half of the bushes were busted)
    this leaves only the rear panhard that isn't new.
  19. The Following User Says Thank You to garett For This Useful Post:
    MB (23rd April 2024)
