Page 23 of 32 FirstFirst ... 132122232425 ... LastLast
Results 221 to 230 of 320
Thread: Garett's ford maverick 1990,
  1. #221
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    Still faster than a Hilux up a hill lol
    Wish I could add a picture got a decent load including a giant canoe
    472 Post(s)
    Radiator/system pressure tested before departure Garret Mate
  4. #223
    472 Post(s)
    FWIW: (safety wise) It’s always worth carrying a full set of 13A belts & top/bottom radiator hoses & ………..heater hoses IMHO!
    Them sneaky rubbery lines over your rocker cover can shut an entire Adventure down
  5. #224
    Jan 2015
    19 Post(s)
    Cooling and brakes were tested prior to departure...in a cane paddock...
    I had replaced all cooling rubber bits and belts 6 years or so ago... She'll be fine lol he says 1800 km in . 4 year old diesel is not the best. Lacked some power. Now it doesn't run on when you turn it off.
  6. The Following User Says Thank You to garett For This Useful Post:
    MB (17th March 2022)
  7. #225
    Jan 2015
    19 Post(s)
    Well 3300km done.. she is starting to sweat horsepower .. and a few other niggles. Like my factory clock. Some rattles to sort but nothing too major
  8. The Following 2 Users Say Thank You to garett For This Useful Post:
    MB (19th March 2022), rusty_nail (19th March 2022)
  9. #226
    472 Post(s)
    Glad You’re Safe & Sound Garret Mate
    Faithful old dinosaurs our TD42’s, keep on trucking with some clean air/filter inspections for added power, no need to always replace, circumstantially can get away with a removable tapout roadside just for good measure
    Damn bugs on forward facing Snorkels
  10. #227
    Jan 2015
    19 Post(s)
    I do need to make a shield for the clutch slave ... its gone walkabout, the pedal gets worse as the day went on then get better the next morning...
    since removing all the weight I doubled the gap between the tyre and the wheel arch ...
    ended up doing a fuel filter beside the road, but surprisingly the tyres held up..
    I do think the old girl could benefit from some new shocks I've put over 100k km on these Monroes
  11. #228
    174 Post(s)
    It was this caused our need to be put on a tow truck half way up the Kuranda Road from Cairns. Clutch jammed, slave cylinder wouldn't release. Car was not driveable. Dropped at the mechanic's after hours. Next morning clutch worked & we drove it into the premises. Mechanic's first & only question was "Do you have a 3" exhaust"? Symptoms & answer of "Yes" had him say "It'll be the clutch slave cylinder. ........ & it was.
  12. #229
    Jan 2015
    19 Post(s)
    I got some headers bout 2.5 inch at the slave, when the pedal went I just shifted without the clutch until I got to town. although not much changing down the highway sitting on 90km/hr.
    sadly its not the first time I have changed gears in cars without clutches ...
  13. #230
    Jan 2015
    19 Post(s)
    grr see a trail of fluid running down the front left .... gotta investigate but I think I've blown a calliper ....
    top tip don't let your old car sit for a long time ...
