7th March 2015, 07:40 PM
#11
Im running upto 25psi and no limp mode..
7th March 2015 07:40 PM
7th March 2015, 07:43 PM
#12
mullet_hunter
Do you have stock air box or any other mods that would help achieve those figures? Also is yours auto or manual. Mine is an auto like the OP
03 ST-L auto, Dawes and needle valve, provent catch can, 3' exhaust. I want more than I got
7th March 2015, 08:02 PM
#13
When my car was getting chip-dynoed, the bloke there told me something I didn't know. The limp mode is caused by a number of factors creating a certain "scenario" when it comes to air/fuel/boost/temperature side of sensors...
The Following User Says Thank You to Hodge For This Useful Post:
7th March 2015, 10:34 PM
#14
stock except hpd maf housing, hpd air box lid, hpd catch can...
The Following User Says Thank You to mullet_hunter For This Useful Post:
7th March 2015, 10:43 PM
#15
mullet_hunter
Yeah with the hpd maf housing and air box lid you can have as much boost as you want.
The Following User Says Thank You to Paule For This Useful Post:
mullet_hunter (7th March 2015)
7th March 2015, 10:52 PM
#16
my egt's hardly ever get over 300...
11th March 2015, 05:45 PM
#17
Still got the limp issue after numerous tweaks. Problem might be elsewhere I think. Would getting a dyno tune fix it?
11th March 2015, 09:38 PM
#18
Dinger
A dyno is a waste of money, unless the person doing the dyno knows how to adjust these valves, and I'm yet to find one. Not saying there isn't...Lol
So. Whats your max boost level? Does limp kick in at anytime your put the boot in or just on certain hills or ways you drive? Have you given the MAF a clean lately?
I will add, prior to me getting the HPD maf housing, I could not get anything over 16psi. And even at that I had to have a fairly slow spool up rate so I wouldn't see limp mode. It wasn't the maf as I had changed it over with no difference.
So what I'm saying is, some ZD30's just don't like boost. Drop your max boost a tad, so if your at 16psi, try and drop it by half or quarter a psi if you can. Then bring the spool up rate back up(winding in the needle valve).
11th March 2015, 10:19 PM
#19
Thanks mudski for the advice. I changed the maf on the weekend. The one I bought from you before xmas. I will take your advice and do the adjustments you advise. I will try it over the weekend and see whay happens. Thanks again
15th March 2015, 09:34 PM
#20
Well my saga is continuing. I have got rid on one point that it goes to limp at around 3200 rpm so it is getting closer to being gone a few more tweets and it should be solved. Thanks for all the advice. I will report when the problem is completely solved. Thanks again
