Results 21 to 30 of 44
Thread: Does 2T have a placebo effect?
    Oct 2010
    Old Bar, NSW
    Yes mate you are correct.
    From my understanding most use a ratio of 200:1 so basically 1/2 a litre to a 90 litre tank that patrols have.
    I had put it in before filling so it mixes with the fresh fuel.
    Macca
  2. The Following User Says Thank You to macca For This Useful Post:
    Patrol-Guy (17th March 2015)
    brisbane
    Quote Originally Posted by Patrol-Guy View Post
    Well I've been reading about adding this 2T. And I think I have the general gist of what you're all talking about but just let me ask this so I'm clear about what to do so I dont bugger things up, so you are saying to add like 500mil of Castrol Activ 2T Motorcycle Oil http://www.supercheapauto.com.au/onl...ecommendations straight to the fuel tank before filling up. And this may or may not improve the running of the motor?
    From what I've read here and elsewhere Any 2 stroke will work just make sure its mineral as it will mix with the fuel better than a semi or full synthetic and that it meets the specs of jaso-fc (low ash for catalytic converters )
  5. The Following 2 Users Say Thank You to megatexture For This Useful Post:
    macca (18th March 2015), Patrol-Guy (18th March 2015)
  6. #23
    Expert Patrol-Guy's Avatar
    Dec 2013
    NSW
    Aug 2011
    River Heads Q
    4 Post(s)
    Yes.
    Went down to Brisvagas yesterday and back-- about 600klm round trip. Filled up at Gympie on way home and added just under 1 lt Castrol T2 between the 2 tanks as was almost empty. Took 159lts. It is 141.4klm from Puma servo to my place and I could NOT notice ANY difference in performance, smoothness or noise. Just started up again from cold to see if any difference but again could not notice and change. Going up to Broadwater Haven near Baffle Creek next weekend so will check fuel economy when I get back from that trip. Fuel economy of trip to Brisvagas and back to Gympie was 13.21lt/ 100k which was almost 1 lt/ 100k better than previous trip after new air filter fitted. Cheap economy these air filters.
    In future, will only use Diesel Power or similar every so often to keep system clean and bug free---unless the 2 stroke improves fuel economy greatly.
  8. #25
    Oct 2010
    Old Bar, NSW
    Had a yarn to an old hand who repairs diesel pumps / injectors on Monday.
    This bloke has been working on fuel systems for so long almost everyone who lives around here that owns an old or new diesel knows his name if not being a customer of his.
    Mine is not starting as quickly as it used to so dropped in to get his advice. It was better today, ( fitted another negative from the battery direct to the engine last night and it was faster starting today, also added DieselPower to the Vortex Monday)
    First up he said add 1:1000 automatic transmission fluid (ATF), he said some long chemical name with lead in it.
    My response was that was going back to old type fuel! He replied with a smile.
    It lubricates and cleans the parts that the sulphur deleted pump fuel no longer does, plus has a small power boost.
    He then said BP Ultimate was the best fuel at the moment, better than the Caltex Vortex I have been using.
    Odd that he said that as our local BP had a big promotional banner out the front, saw it that morning and also a huge billboard extolling the virtues about cleaning a system in 2 tank fill's on the highway to his place.
    Advertising budgets aside he said it was the better fuel.
    Idling you engine is not a good thing, sure warm it up but not for a long time and throw your turbo timer out. He said glazing from excessive idling was not good for an engine.
    And finally I asked about adding 2T, he is a basic down to earth bloke... he said save your money (to buy ATF). It does nothing, quite sure about that he was too.
    Now that is probably a bit of a wind up for a few here, not my intention just passing on information given to me by an old school expert.
    So after putting a couple of tanks using BP and ATF he said call back in and see where we are up to.
    Macca
  9. #26
    174 Post(s)
    I will look forward to you reporting back Macca. In the time it’ll take me to use up the rest of the 2T I have you should have plenty of time to evaluate Ultimate & ATF. Will you try each separately?
  10. #27
    Oct 2010
    Old Bar, NSW
    I have used 2T in the past and didn't notice any difference at all in this car or the 3.0ltr TD Hilux I had before it.
    Engine Noise, smoothness of running, fuel economy all seemed to be the same. Only thing I did notice was the increase in the cost of what went into the tank!
    So gave the idea away, be interesting to see what this BP / ATF does. I will report back.
    Macca
  11. #28
    Dec 2015
    WA
    5 Post(s)
    The ATF sounds scary to me.
    Which one?
    Whale Oil?
    Jojoba?
    Synthetic?
    It is not made to be burnt.
    Graham
  12. #29
    brisbane
    I'd be hesitant to use it also. Wonder how long till it clogs up a cat
  13. #30
    Patrol Freak Touses's Avatar
    Mar 2016
    Childers QLD
    22 Post(s)
    The 2t makes a helluva difference to the pig. Quieter,less smokey and easier cold starts. Keen to hear of trials with the others!
