Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: Exhaust Air Bag
    Patrol Guru cgm's Avatar
    Jul 2012
    Ballarat
    Exhaust Air Bag
    Finally had a go at trying this yesterday and FAILED!
    The quality looks fine from what I can see and I'm happy enough, but I had two issues:
    1. The exhaust has had a chrome tip put on it and it leaked back around the join when I tried to use it, so it just wouldn't inflate (this was the main issue)
    2. I decided to try it under the drivers side and from the exhaust coming out the rear left you can't see what's going on if you are doing it on your own
    I'll take off the chrome tip and throw it away (I often hit it anyway, so should get rid of it). But I never thought about the visibility issues. Just gonna have to do it a bit at a time and check on it I guess. I probably will get a piece of carpet or maybe mudflap to have around incase I want a bit more padding than bit of stuff provided.
    Would encourage anyone to test it before you need it if you do get one of these.
    Edit: Sorry guys, somehow ended up in the wrong thread
    Thanks, Cameron
    No Patrol now - Just good memories!
  2. The Following 3 Users Say Thank You to cgm For This Useful Post:
    macca (3rd March 2015), Stropp (3rd March 2015), threedogs (3rd March 2015)
    Expert graeme1969's Avatar
    Jun 2013
    Wesley Vale, Tas
    Gday. Visibility should not be too big of an issue as there wouldn't be many times if any that you would be on your own, especially out on the tracks.
    ... or, if it is an issue, use a compressor for inflation instead of the exhaust gas.
    cgm (3rd March 2015)
  7. #4
    Jul 2012
    Ballarat
    Ha ha it has been a complete thread hijack. Oh well.
    Thanks, Cameron
  8. #5
    Quote Originally Posted by cgm View Post
    No biggee... the Moderator will move it when they get a chance
  9. #6
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Couldn't decide where 2 stick it so stuck it under Essential Toolbox Items.
    .................Well at least I moved it
  10. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    cgm (4th March 2015)
  11. #7
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    I've been meaning to give mine a go at some stage also. I've got the same one
    Lucus30's 1999 GU ST TB45E
  12. #8
    Ballarat, Vic
    174 Post(s)
    Must try mine at some stage. It has both a ‘funnel’ like yours to push over the exhaust, but also has a valve to fit a compressed airline to.
  13. #9
    Hardcore jack's Avatar
    Ballarat Area
    25 Post(s)
    I had to put a chrome tip on my exhaust as it was cut at 45 degree angle, works fine but be careful you don't get coated in soot if you don't hold it tight. Never tried the compressor fitting, wonder how quick it would be.
    Jack
  14. #10
    Patrol God Stropp's Avatar
    31 Post(s)
    yes i had to get rid of my chrome tip as well as it was cut at 45.
