26th September 2018, 04:50 PM
#11
I have the same problem except i have 3 spotlights 1 led and 2 ipf spotlights the led's working fine the 2 ipf are not and and all are good the wires to the relay are also working i have checked the fuses and are all good.
Any ideas on whats going on would be appreciated.
26th September 2018 04:50 PM
26th September 2018, 07:32 PM
#12
I am he, fear me
How have you earthed the IPF's?
Do you have 12 Volts at the IPF's them selves?
Are all 3 off the one relay?
26th September 2018, 09:17 PM
#13
They are all off the 1 relay,they worked fine until the bull bar was replaced due to an accident. ( they were on the patrol when i bought)
27th September 2018, 12:47 AM
#14
I am he, fear me
shags1975
Fair enuf... assuming the IPF's survived the accident then I would suggest the IPF's aren't earthed.
Do you have a test light or Multimeter?
Unplug an IPF and see what you get between power and earth... or...
Unplug an IPF and run a jumper from the LED or any known 12volt to an IPF and another jumper to earth
27th September 2018, 08:41 AM
#15
in the past ive seen corrosion on the back of the spot lamp globe. usually after a lot of water crossings.
