12th March 2015, 02:11 PM
In a perfect set up yes then the exhaust drives the turbo not the ecu so much,
In your case you may need to drill a 10mm hole in the EGR plate so the ECU
doesn't throw up the engine light all the time, unless you have a scan gauge or similar
12th March 2015 02:11 PM
12th March 2015, 04:08 PM
Yes I've got a scan Gauge so will be able to clear
engine light if or when it comes on
12th March 2015, 04:57 PM
would it be worthwhile taking the IC off and pressure testing it.?
13th March 2015, 11:34 AM
That should be easy enough to do
I wonder what sort of pressure it would take
Probably not much needed to test
13th March 2015, 11:39 AM
I would only use a bike pump, or a quick squirt with the air gun ,tape up one end
and dip it in some water,
Dry with a hair dryer before installing again.
22nd March 2015, 09:59 PM
When was the last time you changed the fuel filter
22nd March 2015, 10:00 PM
#17
Had my surge under load and check light come on
22nd March 2015, 10:01 PM
#18
I check codes and it said dirty fuel or blocked fuel filter Chaged fuel filter and problem solved
23rd March 2015, 10:59 AM
#19
It's going in for a service (40,000ks) this week so I'm waiting till that's done
before I do much else.
14th June 2015, 01:51 PM
#20
Just an update Nissan seem to think its a turbo problem
I'm getting a new turbo fitted next week all going well.
It's still under warranty so price is right will see what happens
