Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Turbo Surge Under Boost
    In a perfect set up yes then the exhaust drives the turbo not the ecu so much,
    In your case you may need to drill a 10mm hole in the EGR plate so the ECU
    doesn't throw up the engine light all the time, unless you have a scan gauge or similar
    Jan 2015
    Yes I've got a scan Gauge so will be able to clear
    engine light if or when it comes on
  4. #13
    would it be worthwhile taking the IC off and pressure testing it.?
  5. #14
    Jan 2015
    That should be easy enough to do
    I wonder what sort of pressure it would take
    Probably not much needed to test
  6. #15
    I would only use a bike pump, or a quick squirt with the air gun ,tape up one end
    and dip it in some water,
    Dry with a hair dryer before installing again.
  7. #16
    Mar 2015
    When was the last time you changed the fuel filter
  8. #17
    Mar 2015
    Had my surge under load and check light come on
  9. #18
    Mar 2015
    I check codes and it said dirty fuel or blocked fuel filter Chaged fuel filter and problem solved
  10. #19
    Jan 2015
    It's going in for a service (40,000ks) this week so I'm waiting till that's done
    before I do much else.
  11. #20
    Jan 2015
    Just an update Nissan seem to think its a turbo problem
    I'm getting a new turbo fitted next week all going well.
    It's still under warranty so price is right will see what happens
