27th February 2015, 11:12 PM
Turbo Surge Under Boost
This is a carry on from another thread I may have hijacked a bit.
My car surges a bit whilst under acceleration Boost fluctuates
between about 11 psi to 16 or so. The car is a 2012 ST Cab chassis
3"exhaust Anything else is unknown at the moment. There is no external
sign of oil near or around the inter cooler although there is some visible
when you remove the intake hose. Inter cooler is standard
Still need to check the boost lines / hoses
Any thoughts
27th February 2015 11:12 PM
28th February 2015, 08:17 AM
Id be checking all boost and vacuum lines
What does it do if just cruising at say 60kph
2nd March 2015, 01:28 PM
sitting around 60ks car seems fine Only really happens
when running thru the gears I had a quick look at the
Vacuum and boost all seem tight and sealed I'll have a
better look during the week
2nd March 2015, 01:53 PM
Maybe your IC is leaking as well, spray any sensors
making sure they are dry before re fitting them
3rd March 2015, 11:39 PM
Thanks for the reply Will check inter cooler, Would MAF sensor
cleaner be ok for any sensor If you run it upto or past 3000 rpm
there doesn't seem to be any fluctuation So may just need to drive
it a bit harder
11th March 2015, 10:02 PM
Got the same problem with mine - 2013 ST manual wagon. Looked, checked and cleaned everything I could find. A real pain in the b-m. Read heaps on the subject but no one seems to have a definitive answer. I am sure there are several possible causes so it is next to impossible to pin it down to just one or two things. I'll keep looking and checking as an when I can but running out of enthusiasm. If someone knows of someone else who has found a magic bullet I would be more than interested to know what they discovered.
11th March 2015, 10:09 PM
Would dawes and needle valve solve this problem, taking boost control away from ecu and doing it manually?
02 GU ZD30 Auto, NADS, Setting up for touring and camping, Best thing is the missus loves driving it to..
12th March 2015, 11:05 AM
I was thinking this may be worth a try
I don't think a Dawes valve ect costs much
so might buy them and see.
12th March 2015, 11:24 AM
Getaboutabit
You'll need to fit some gauges to monitor your boost and egts once the egr block is in place
12th March 2015, 12:17 PM
I've got Boost and EGT Gauges fitted
Do I need to block egr?
