8th March 2015, 09:02 AM
ZD30 CRD Oil Filter.
Anyone know how to remove a stuck oil filter? I had it serviced just after I got the car and it looks like the oil filter was tightened with a rattle gun. I've tried a half inch socket driver, torque wrench, air ratchet gun and the thing won't budge. Had to ruin $70 of Nulon Oil so I could drive the car again.....
GROOVY GUVII
8th March 2015 09:02 AM
8th March 2015, 09:15 AM
clubbyr8
Are you talking about the filter or the sump plug ???
8th March 2015, 09:30 AM
Hodge
The Oil Filter....
GROOVY GUVII
8th March 2015, 09:38 AM
I used an extra long brako bar when mine was tight.
Eventually got it, give it a hit to shock it and even try put an extension on the bar it will come
Take your time
The Following 2 Users Say Thank You to threedogs For This Useful Post:
clubbyr8 (8th March 2015), growler2058 (8th March 2015)
8th March 2015, 12:56 PM
clubbyr8
The Oil Filter....
Ok. It wasn't a smart - arse question. I was wondering how in the world do you fit a rattle gun or air ratchet in there. It is tight as ! Hence why I thought maybe you're thinking of the sump plug.
8th March 2015, 01:21 PM
Hodge
It's cool. The rattle gun doesn't fit, not sure what the mechanic used, maybe he's got a right-angled rattle gun (if there's such a thing). Had to use a rattle gun to loosen the sump plug so I assumed he did everything up that way. The air ratchet gun fits easily but won't budge the filter cover. Guess a need a longer handled breaker bar...
GROOVY GUVII
8th March 2015, 01:54 PM
Grab a 12" shifter and see if the hole in the handle (where you would hang it up from) will fit over the breaker bar. If it does then you can use it for extra leverage. If it doesn't then try a ring spanner but be careful not to snap the ring on the spanner. A piece of pipe over the handle of the breaker bar can also work. Hope this helps
03 ST-L auto, Dawes and needle valve, provent catch can, 3' exhaust. I want more than I got
The Following User Says Thank You to Paule For This Useful Post:
clubbyr8 (11th March 2015)
8th March 2015, 03:03 PM
#8
I am he, fear me
Haven't found an oil filter yet that one of these suckers won't get off
http://www.gettoolsdirect.com.au/kin...FY6XvQod0gcA-A
The tighter the filter the harder they grab hold
The Following User Says Thank You to the evil twin For This Useful Post:
8th March 2015, 11:46 PM
#9
Filter cover has 1/2 drive square in it and it is suppose to be only tightened to 25 Nm.
It is possible that it was fitted dry and overtightened as well.
It wiil need a bit of impact to loosen but carefull approach is needed as both housing and filter cover are alumminium and will crack easily if too much force is used. It will cost $$$$$ if that happens.
Tap on the end of breaker bar might give it enough shock to loosen but the thread might already be damaged by than. Take care when imposing undue force.
Regards
The Following User Says Thank You to Rumcajs For This Useful Post:
9th March 2015, 02:48 PM
#10
I had this issue when my 2006 Gu 3.0 was relatively new. My mechanic tried then quit because he was worried about breaking an expensive part. He sent me to the Nissan dealer and they got it off--not sure how, but since then it seems to be a non issue. May be cheap insurance to have the dealer do it. :-((
The Following User Says Thank You to Dr Gary For This Useful Post:
