Results 41 to 45 of 45
Thread: Ultimate GU Stereo Installation - Lots of pics
  1. #41
    103 Post(s)
    Quote Originally Posted by Navarra View Post
    Flex, Thank so much for sharing all your knowledge on your mod. There is so much I can pick from your experience.
    I have just started on a project to upgrade my audio systems ( a 2001 Patrol GU). I putting in a Alpine 2-din head-unit and replace the front speaker with a split component speakers, its an Alpine SPR-60C. Got the head-unit in yesterday and now working on the speakers. I am planning to install the tweeters on the pillar trim. Will be drilling a hole on it and flush mount. I hope there is enough room.
    Hi Navarra no harm done but can you pop over to the intros
    and tell us a bit about yourself, just something the Forum
    asks of us all, Polite and all
    Jul 2015
    Oops, done
  4. #43
    Aug 2017
    Where did you route the power cable through the firewall for your amp?
  5. #44
    Advanced Flex's Avatar
    Sep 2011
    Melbourne, Australia
    I routed all my cables through the passenger side factory grommet. You have to un-tape it in the engine bay to get the cables through, which is very hard. Another option is to use the manual pedal hole if you have an auto.
  6. #45
    Feb 2017
    Perth
    After reading all the useful posts, I set about installing new front speakers and tweeters in my GU Y61
    While at the end I am happy with the result, I also made a couple of mistakes that I am about to describe hoping to help others not do the same......
    After unscrewing the fitting between the door and the car where all cables go through, I realised that there is a multi-pin plug that precludes passing another cable through, so I decided to put the tweeters in the door.
    Not knowing how to remove the door trin I made a couple of mistakes:
    I removed this trim which is not necessary to do.
    Then I pried open the window switch instead of just removing the two screws and subsequently lost a 3mm ball bearing.
    After that I drilled thehole for the tweeter:
    And installed it:
    Then drilled 10mm hole to pass the cable to the speaker gain control box:
    and fitted the box:
    Before reinstalling the door trim, I tightened all screws in the panel behind that were all loose (two had fallen to the bottom of the door:
    Before reinstalling the door trim and the speaker, I put some shock cord in the old, stretched, elastic mesh:
  7. The Following 5 Users Say Thank You to Spiv For This Useful Post:
    GQtdauto (15th April 2018), innocent.bystander (10th May 2018), MB (15th April 2018), PeeBee (15th April 2018), rusty_nail (15th April 2018)
