20th February 2015, 07:32 AM
Hose size for transmission lines 2001 GU Auto
Hi all,
Does anyone know offhand the internal hose diameter for the 2 hoses that run from the transmission to the radiator? I need to buy a short length to loop them around and connect each other. Looks to be around 6mm?
20th February 2015 07:32 AM
20th February 2015, 08:30 AM
Trans cooler hoses are 5/16"
John
The Following User Says Thank You to jff45 For This Useful Post:
Xtreme (20th February 2015)
20th February 2015, 08:48 AM
which would translate to 8mm
23rd February 2015, 11:05 AM
jff45
I should add that aftermarket trans coolers (my Davies Craig anyway) use 3/8"
John
4th September 2017, 05:56 PM
would this be right for a 99 GU (4.5lt)
