27th August 2011, 05:14 PM
#11
Banned
guterra
Hey fellas, also new here... But just a bit of advice... One of my "best money well spent" was on an ecutalk (or scangauge). It will read and reset fault codes and display realtime info, so you know what is going on, and you can set alert tones on coolant temp, voltage etc...
My alternator failed recently as well, but I knew straight away from the ecutalk. Slapped another on, and away I went.
Well worth the $220 odd bucks and saving an engine from overheating by the coolant alarm.
Top advice mate, but can you also slip into intros as per the other post ..
I've got the Nissan Data Scan software with the ECUTalk device and they're bloody bottlers!
27th August 2011 05:14 PM
27th August 2011, 05:22 PM
#12
Bigrig
The ECUTalk probably won't work when we put the programmable injection on Tank. Shouldn't matter if it doesn't work, you'll be able to plug your laptop in instead.
Tony
