1st April 2015, 06:56 PM
Travelling Podologist
Kempy
Just out of curiosity but why does he pull the butterfly out?
Once the egr valve is blocked the butterfly becomes superfluous & only serves to create a restriction to air flow. That’s as I understand it, others might offer more detail.
1st April 2015 06:56 PM
1st April 2015, 10:56 PM
well, after reading TimE write up.........
bugga me, I dont have to worry about it
mine was a NA and I added the Turbo & intercooler from a 2006
so the butterfly is already disconnected and I dont have the EGR to blank off either
mine is wholey and solely NON computerized, so they were never connected up
cheers anyway Cuppa
13th December 2018, 06:21 PM
Bit of a thread dig...
Will be doing the entire removal this weekend. Well, whats left of my EGR system, which is basically the heat exchanger, associated coolant lines and the pipe at the back.
I have found this kit at Patrolapart. (pic below)
Everything is very straight forward. Only one thing I'm confused about.
The coolant T piece at top of motor, is removed and a in-line pipe is inserted. (pictured below)
But...
What happens to the coolant barb on the block ?? How is it blanked off? It does not appear to be in the kit.
@nissannewby
14th December 2018, 08:19 AM
I think its a threaded port into the block. You would remove the fitting and put a blanking plug in there. As for the size. I am not sure. I can have a look on the Nissanfast parts program tonight to see if it tells me anything.
Hodge (14th December 2018)
14th December 2018, 11:48 AM
mudski
Newby got me sorted mate. It's a blanking plate , after you take off the barb plate. Just picked the kit up from Patrolapart before.
Taking off the pipe at the back will be the biggest challenge. It's a contortionist challenge.
mudski (14th December 2018)
14th December 2018, 05:50 PM
what this have to do with anything
15th December 2018, 01:23 AM
#17
Donnie
Welcome aboard Donnie mate?
