my Patrol broke down 2 days ago and i pulled the gearbox out. I´m wondering if the shaft what comes out of the engine is broken too? Or do i need only a ned flex plate?
Was the convertor bolt missing or did you remove it? If it fell out, it could have played a role in the problem allowing the plate to flex more.
I don't quite understand why we can't see the 7 bolts that bolt it to the crankshaft. Is that the end of the crankshaft in the centre?
John
