5th February 2015, 09:46 PM
#31
Travelling Podologist
Once the fridge issues have been examined, if more ventilation is needed the scupper vents I mentioned earlier would work but would need to be closed in the rain. I was confusing them with muller vents, a couple of which would probably be better. The venturi effect would suck out heat whilst allowing some fresh air in. The place I’ve linked to is somewhere I’ve dealt with on many occasions. They are on the ball & very professional.
The Following User Says Thank You to Cuppa For This Useful Post:
DX grunt (5th February 2015)
5th February 2015 09:46 PM
6th February 2015, 01:01 AM
#32
When I worked for Telstra we used to fit boat vents that had a pipe up into the scoop part to keep water from entering the pod
6th February 2015, 01:05 AM
#33
Dribble Master
threedogs
I like the one I put up more......... I reckon 2 of them would look great on top of Grunters pod.
11th February 2015, 10:06 AM
#34
hey DX, what about the old Escort Panel Vans??
they used to have a vent on the back of the roof - for exactly what you are wanting
if you can find one.......
The Following User Says Thank You to Bigcol For This Useful Post:
DX grunt (11th February 2015)
28th February 2016, 10:59 AM
#35
Hey DX what did you settled on and how well does it work? I am looking into sleeping in the pod with potentially the doors closed but still enough ventilation going on.
