5th February 2015, 12:46 AM
firm351
Mines the same, as soon as it sees an incline in the distance it drops back a gear and revs its box off. I never use cruise anymore it shits me to tears.
yep mine shits me to tears,i don't bother with it either..i wouldn't drop my car back a couple of gears and watch it hit nearly 4500rpm in an instant,don't know why they make it do this with a computer
5th February 2015 12:46 AM
5th February 2015, 07:07 AM
Ok. Quick q. What tyres are you all running??
I'm thinking if bigger the auto already has a bit of extra strain on it. So less incline is needed for it to drop back.
5th February 2015, 09:54 AM
Get it serviced, I have an Autron CC and it will hold 110 day in day out.
See what happens after your service,
out of interest what size tyres are you running and what is your fuel consumption,
If your getting around 14/100 I would say thats normal
5th February 2015, 11:26 AM
I have an Autron fly by wire cruise control and it does not do what the factory cruise seems to do. It does of course kick back on steep hills but not on small inclines (unless I am heavily loaded or towing). When I am approaching a hill I usually "help" the auto by clicking out of OD. I can't see how it is the auto's problem if it does not happen when you are driving it with cruise off. What setting is your three position A/T switch in? I usually leave mine in the middle (normal) position. Try the "Power" or "Hold" position on the same hill and see if it makes any difference.
threedogs (5th February 2015)
5th February 2015, 02:38 PM
Tyre size has nothing to do with it, I run two sets stock and 33s and makes no difference what I'm wearing
5th February 2015, 04:50 PM
I have the autron cruise in my 03 3ltr and it's great, I reckon it must be the factory cruise control module making it kick back
5th February 2015, 05:02 PM
#17
Yeah mine can do the same occasionally, although not on a small incline more of a short sharp hill, ie around Warragul coming back from Melbourne, there is a little hill there that always does it while the rest of them are fine, I know our car is not a CRD but Di like yours and others but it still is not an ideal Cruise control system and same thing shits me of but then also I think our torque converter is on its way out and needs looking at soon.
02 GU ZD30 Auto, NADS, Setting up for touring and camping, Best thing is the missus loves driving it to..
5th February 2015, 06:52 PM
#18
How can you tell if the torque converter on the way out? My tyres are 285/70 -17's btw. Im thinking its just the shitty nissan factory cruise. Being a truck driver I use cruise constantly...even in the cities to keep speed down but looks like the Patrol will have to be cruiseless unless on flat road!
5th February 2015, 08:29 PM
#19
DiE_PoTaTo
Release of throttle and then re apply (corners at giveway signs, round abouts, cruising at 80 ect) and engine revs slightly before transmission re engages (sometimes it does sometimes it does not do itand is inconsistent in doing it, its less often on mine than more atm), coupled with slight vibration when applying throttle but only when transmission is engaged, topped with 230 tho /k's on vehicle it seems a likely possibility but open to suggestions. All oils are new and correct levels including new filter/strainer and pan removed and cleaned, was doing it before all that was done as well, not overly worried about it atm but will be on the to do list and check at some stage.
