Results 1 to 4 of 4
Thread: Patrol Z30 Flexplate snapped
    Feb 2015
    Hi there,
    my Patrol broke down 2 days ago and i pulled the gearbox out. I´m wondering if the shaft what comes out of the engine is broken too? Or do i need only a ned flex plate?
    Tim
    http://imageshack.com/a/img673/9899/GG60OG.jpg
    http://imageshack.com/a/img905/9566/EahlsO.jpg
    http://imageshack.com/a/img908/1929/FZip7Q.jpg
    464 Post(s)
    The shaft you refer to is the crank shaft. I wouldn't think it's damaged, while you have it apart, put a new rear main seal in.
    Beginner onlyme376's Avatar
    Apr 2013
    gracemere
    ouch that looks nasty, I'd be more worried about the input shaft to the auto the crankshaft should be fine
    2006 gu iv 3l auto st-s wagon
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    Was the convertor bolt missing or did you remove it? If it fell out, it could have played a role in the problem allowing the plate to flex more.
    I don't quite understand why we can't see the 7 bolts that bolt it to the crankshaft. Is that the end of the crankshaft in the centre?
    John
