Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 79
Thread: Runva 11Xp Install to Genuine Nissan Bar
    Patrol Guru Rocket55's Avatar
    Sydney
    Yep, I know what you're saying. I got stuck a few weeks ago and had to winch, but all worked well. I still don't trust the wireless bit (worked fine on the day) thats why I put in cab whinch controls. Extend the 3 wires up into the cab, put an Momentry On - Off - Momentry On switch in and you're done.
    Cheers Rod
    My Build 2005 TD42TI
  2. The Following 2 Users Say Thank You to Rocket55 For This Useful Post:
    Bacho86 (29th January 2015), Smoothrun (30th January 2015)
    43 Post(s)
    Quote Originally Posted by Rocket55 View Post
    This is on my to do list.
    I plan on putting it in my center console as I think anything on the dash would be a pain to hold while steering and winching.
    Patrol Guru
    Jul 2014
    6 Post(s)
    It's a good spot, easy to get to and comfortable, and can be reached by both driver and passenger. Only down side is the dog has hit it a few times when she's decided to jump up front. I've got an isolator switch for it as well, so fortunately she's never happened to flick both!
  6. The Following User Says Thank You to Throbbinhood For This Useful Post:
    BigRAWesty (29th January 2015)
  7. #24
    Sydney
    Yep, mines on the centre console, great spot.
    Cheers Rod
  8. #25
    43 Post(s)
    Quote Originally Posted by Throbbinhood View Post
    Yea isolator is behind the steering wheel. So that one is safe lol
    Expert Smoothrun's Avatar
    Dec 2012
    Vic Melb
    Thanks for that Bacho86, I can mount mine on the passenger side bracket opposite to yours, hows it holding up, I didnt get to me mates as hes crook as a dog, he offered but decided to let him RIP.
    Ive got some 2mm plate here so Ill use the original mount bolted to that and bolt as you have to the side brackets, thinkin about mountin the Isolator off that too, I got the longer 10mm top bolts from Economy in Dandy today and they are identical to the original fairled bolts, stainless, Hex and rated at 7.2, more than enough, looks pretty good, just gotta mount the rear protector plate once I mount the control box, the bottom plate fitted in perfect with about 20mm spare, If i didnt turn it upside down would have had to get the grinder out just for the clutch handle, so all fitted nicely.
    Ill add more pics when done so others can take everything into consideration for future reference, Thanks for your input everyone, Cheers
    Lifes a journey not a destination.
  10. #27
    Dec 2012
    Vic Melb
    Great, now one projects just turned into another lol, Top idea that, read it once before somewhere a while ago but think ill go the remove + from battery for the winch for now, I had another look at the isolator and they arent too bad actually I dont have the crimping gear for the big cables but keen to give it a go too, seen it on spew tube and recon it looks fairly easy.
    Thanks Rocket55
  11. #28
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Quote Originally Posted by Smoothrun View Post
    Thanks Rocket55
    Come to mine if you want I've got a crimper
    Lucus30's 1999 GU ST TB45E
  12. #29
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    It's holding up well so far - but I haven't done any extreme corrugations or anything yet. Just one of those things to keep an eye on
  13. #30
    Dec 2012
    Vic Melb
    Cheers mate!, and thanks for the offer, Im not gunna worry about it for now, Ill decide on a spot for the isolator when I fit up a couple of other things on me list, what crimper have you got, Im gunna have a sqiz on fleabay and buy a decent one, Me mates a fitter and used to work open cut many moons ago, Ive seen him do all his old style years ago (with a cold chisel) but know he bought one a while ago so ill suss him out when hes not busy.
