30th January 2015, 10:02 PM
#31
Bacho86
It's holding up well so far - but I haven't done any extreme corrugations or anything yet. Just one of those things to keep an eye on
I recon itll be ok, I fitted mine too close to the grille and couldnt put the remote plug in, , worked out good because i simply took it off and bent the mount at a 45, worked out great cos now it rests solid on the winch housing too. doesnt even flex, ill keep aan eye on that and pack it up if the need arised.
Lifes a journey not a destination.
30th January 2015 10:02 PM
30th January 2015, 10:05 PM
#32
I noticed today that there was a light blue cable sittin in the control box, I recon it might be the cordless remote lead, I didnt do it but if I have dramas with the remote first thing ill do is pull that lead outa the control box.
30th January 2015, 10:10 PM
#33
OK after family left I jumped back onto it to finish the wiring, Not sure what ive done or need to do, but the winch is winding in when selecting out on the remote, and visa versa, any thoughts anyone, do i need to change the blue and yellow leads, cos I turned it over, change the rope on the spool. Im stumped, please help.
30th January 2015, 10:13 PM
#34
That blue cable is the antenna for the remote. It is wired to a separate unit which feeds the solenoid along side of the plug.
If you open the unit up you will see 2 red wires running off the positive solenoid post. Take them off and run them threw a switch in the cab. This will switch on and off the control units.
The Following User Says Thank You to BigRAWesty For This Useful Post:
Smoothrun (30th January 2015)
30th January 2015, 10:38 PM
#35
Patrol Guru
I just followed the standard colour coding and it all worked the right way. Double check you have gone blue to blue and yellow to yellow.
Cheers Rod
My Build 2005 TD42TI
The Following User Says Thank You to Rocket55 For This Useful Post:
30th January 2015, 11:25 PM
#36
biggqwesty
Sound good, Ill do that, thanks mate
30th January 2015, 11:32 PM
#37
Rocket55
Yep, Checked that already Rocket, The rope is drawing from the top of the spool as I needed, all I did was turn the winch over which shouldnt make any difference to in or out. control lead only goes in one way so its not that. Best I can do is email Runva,
Edit,,,
Just for the record i tested it with the wireless remote and in was in, out was out, gotta be a stuff up on the hard remote,remote socket on control panel, or the wireless remotes incorrect lol, gotta put all possibilities out there.
Have emailed Runva should geta a reply tomorrow or Sunday.
31st January 2015, 01:03 AM
#38
Thought id update some pics for reference
These show the bbar support brackets side brackets ive been mentioning, i simply removed it drilled the holes and used stainless bolts
I also used longer bolts underneath for the control box
I have more pics but these show the positioning, the last one has now changed as I bent it a little and thats made it more solid, just didnt taka a pic yet.
The Following User Says Thank You to Smoothrun For This Useful Post:
Bacho86 (31st January 2015)
31st January 2015, 09:30 AM
#39
Seen a post elsewhere that the Runva 11xp is selling for $600 which includes free install as well from Shents Automotive at North Wyong NSW. Not a bad deal really.
31st January 2015, 11:12 AM
#40
Smoothrun
Nice work mate, looks like it came together nicely - hopefully you get the controller issues sorted out quickly!
The Following User Says Thank You to Bacho86 For This Useful Post:
Smoothrun (31st January 2015)
