22nd January 2015, 05:00 PM
Overheating Problem - Please help
G'day,
I am having a problem with my 2002 GU ZD30 Patrol. the other day I was driving on the freeway and noticed that the temp gauge was just above 1/2. It was a warm day and I had the ac on but this was unusual (never seen the temp go up in the car). subsequently it returned to normal and then didnt do anything for a couple of days, but now has started playing up all the time heading to 3/4 frequently. Im not losing any coolant, the overflow tank is on min, I can see the radiator fluid moving so I don't think it is the pump. What I think it may be is the fan clutch slipping. Is there anyway I can test this? When the car is hot with the engine off I can spin the fan with little to no resistance.
The second part to the question is if it is the fan clutch can I change the silicone in it? I understand that the fan clutch and water pump are a unit, is it possible to take the pump off so that I can take the front off the fan clutch to replace the silicone?
Any other suggestions would be appreciated
Phil
22nd January 2015 05:00 PM
22nd January 2015, 05:34 PM
I am he, fear me
Your viscous hub is definitely stuffed if that is the case
If you want to give it a crack at a refurb you need two tubes of the silicon from Toyota.
23rd January 2015, 04:47 PM
hi Phil
my first reply missed so a quick responce check if the Nissan coolant has been contaminated with an other product as this may cause a granulation residue to form in the radiator tanks, if so the fix is a radiator cooling system Flush.
barnelly
2012 GU Y61,
Bull Bar, D/Lights, Alloy 1/2 rack, Warn winch, side steps,Snorkel, Remote coms / mobile & UHF,Dual batteries, set up for camper towing remote areas. nick name " Chuck "
23rd January 2015, 04:57 PM
Also as above but mixing coolants will cause a glagging effect and turn your coolant to gel. [Goat syndrome]
Read overheating 2010 model by goat
23rd January 2015, 05:02 PM
BIG & BALD
Has the car been recently serviced.
A few have changed their caps aswell.
