Results 1 to 10 of 15
Thread: GQ ARB Bullbar fitting.
    Expert Jimmyboyjr4's Avatar
    Penrith, NSW
    Hey all,
    Anybody by any chance have a copy of the fitting instructions? I bought one of eBay but I want to check I'm not missing any thing before I chuck it on the Maverick.
    Cheers!
    43 Post(s)
    Simple as mate. Slide the captive nut plates in, and put in the holding bolt.
    Then slide the bar on and install the 6 bolts
  4. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Jimmyboyjr4 (19th January 2015)
    Penrith, NSW
    When you get a kit is it just the bullbar? or are there other parts? (mounting stuff, bracket etc)
    Oct 2011
    Essendon
    You should also have 2 mounting plates with captive nuts that slide inside the chassis rail with the bolts to suit..
    Sent from my iPhone using Forum Runner
  7. The Following User Says Thank You to Drewboyaus For This Useful Post:
  8. #5
    Penrith, NSW
    So I just went went and picked up the bar, I'm really happy with it and it's in pretty good condition. On the back though there is a slight bit of surface rust, I've never treated rust before though. I was thinking about sanding it back, priming it and then painting it with POR15 as it seem pretty good for the application. Is this the best way to deal with this?
  9. #6
    Penrith, NSW
    Although after looking at prices I may not usr POR15 yet, anything cheaper I could use? or should I just bite the bullet and speak to a powder coater? As from what I've read its not too expensive and will last a lot longer than any I can repaint it with.
  10. #7
    Oct 2011
    Essendon
    Pretty sure a number of folks have just primed and then used a black spray pack.
  11. The Following User Says Thank You to Drewboyaus For This Useful Post:
    Jimmyboyjr4 (20th January 2015)
  12. #8
    Penrith, NSW
    Thanks, I had thought of that and given it's in a fairly hidden spot I'm not too concerned of the look either. Just want something fairly resilient, this 3 step KBS stuff looks the goods plus given I wanted to give a few thing under the frame nice coat it might be a good purchase.
  13. #9
    Quote Originally Posted by Jimmyboyjr4 View Post
    First you would need to sand blast the bar about $100 then powder coated about the same.
    if you get it powder coated dont forget to get it clear coated as well.
    POR15 is an awesome product,,,but have not heard of ppl doing a bullbar though
  14. #10
    43 Post(s)
    Just to remove any shock.
    I priced a blast and re powder coat for a bloke who wanted me to mod his bar...
    $500....
