17th January 2015, 09:28 PM
grinding noise from shaft while in 4wd and in mud
Got a question for the forum. Is it normal to feel a grinding like vibration from the driveshaft to filter through the floor boards when in 4h mode treading through thigh high mud as water?
17th January 2015 09:28 PM
17th January 2015, 09:57 PM
Moderator
Check your tail shaft and unis and see if they are aligned. If the unis at each end on your tail shaft are out is sinc they will vibrate
Check out my Toy -->
Rogue Dung Beetle
17th January 2015, 09:59 PM
Moderator
Rogue Dung Beetle
17th January 2015, 11:46 PM
That could be it. The front wheels were in a ditch while the back wheels were a bit higher and I was moving forward in a 45 degree angle. The noise was intermittent.if they are not aligned what's a fix?
18th January 2015, 02:54 AM
Moderator
remove, spin 90degrees and refit. 4 bolts only just rotate one end.
Rogue Dung Beetle
19th January 2015, 04:27 PM
Thanks mudrunner. I will get on it as soon as I get some time off work!
