Results 1 to 5 of 5
Thread: GQ patrol Sender and tank differences
    Advanced
    Feb 2013
    Hello, my fuel tank is leaking and the leak is coming from the sender unit in my GQ patrol.
    Nissan have told me there are 4 different fuel sender units for this car.
    The tank I was told was from a GQ patrol ute.
    I need to know does anyone know if there is a difference with the tanks and senders and if so how can I find out what sender I need. the sender I have in the tank right now leaks and has a 2-3mm gap around the sealing rim of the tank.
    I have tried a new o ring and hasn't solved the problem
    thanks for the help
    Patrol Freak liftlid's Avatar
    Nov 2010
    6 Post(s)
    Check if you have the low fuel warning light, early models didn't
    581 Post(s)
    As mentioned above but both senders will work but if you have the later model it needs the sensor which is horribly more expensive to buy.
    Quote Originally Posted by Marti View Post
    Did you just buy this tank and put it in?
    Struggling to understand how there is a 3mm gap though? If you have recently purchased it I wonder if there is a different sender put in.
    Does the main pick up line hit the bottom of the tank before the top plate can seal properly?
    When I did my auxiliary tank on the td42 using the tb42 tank needing a new sender I had to trim off some of the pick up line otherwise it wouldn't seal.
    I also ran some gasket seal as it slightly leaked as well.
    Advanced
    Feb 2013
    3mm gap from side to side not top to bottome, the sender hits the bottom then compresses the spring to sit flat in the tank, no low level warning light on it. ill try get a new seal and run some sealent
  6. The Following User Says Thank You to Marti For This Useful Post:
    AB (12th January 2015)
  7. #5
    Patrol Guru
    Apr 2011
    Melton
    Sounds like the O ring is comming out of the grove - I had the same problem first time I fitted a senderI uses a slim knife to force the o ring into the grove.
    1991 GQ LWB 4.2 Carby dual fuel, 32 mud claws, 2 inch lift, LSD's front and back
    And its Toooooooo High for the Ball & chain
