Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: EDS engine data scan vs Scanguage II
  1. #21
    138 Post(s)
    I think there were also some threads deleted from the 4wd action forum about it.
    Patrol Freak Bacho86's Avatar
    Mar 2011
    13 Post(s)
    Gee doesn't that sounds all too familiar... I really hope Berrima Diesel thought long and hard before getting into bed with EMG / 4WD Action
  4. #23
    Aug 2015
    Cairns
    My experience with the EDS:
    After the initial install I didn't bother to do all the set ups immediately and all appeared to work well....
    After making all the basic settings, date, time, engine size, fuel tank size, fuel type and cost I noticed that the Trip meter was no longer working, this includes the instant fuel consumption display.
    So I reset the device and all was once again in order. Settings once again adjusted as above and again trip display showed *NOT SUPPORTED*
    I then went through each setting one at a time and have found that by not setting the fuel type the trip function continues to work. I have also not setup the fuel cost function as yet but it does seem to be working.
    There is an adjustment for Fuel Cut Off which is apparently variable for different makes of car and changes how the fuel consumption displays. However, there is no information given on how this adjustment affects the accuracy or what setting is suitable for which vehicle. At present with the default setting the instantaneous consumption shows a reading I think is plausible but when running against compression with the throttle closed the consumption increases. I will be fiddling around some more to see what happens.
  5. The Following User Says Thank You to GUDriver For This Useful Post:
    neilo99 (24th February 2018)
  6. #24
    Sep 2015
    I received my EDS for my GU and didnt work with the trip computer, when i spoke to berrima diesel they wernt aware of any issue, I said you got to be kidding there is entire thread of negativity
    they said bring it back and we will look into it and test on our nissa patrol, i said mate doesnt work and will never.
    anyway going to make a formal complaint to C&M magazine
  7. #25
    May 2016
    Brisbane
    I had a EDS on my 2012 3.2l BT50. could not read 1/2 the parameters of the available in scan gauge.
    apart from he bt50 being a piece of shit and Mazda being arseholes the EDS was on the same level.
  8. #26
    Expert Boinzo's Avatar
    Dec 2015
    Brisbane
    I've tried both an EDS and Ultra Gauge. What I really wanted was reliable Fuel Economy info for touring. I went nuts trying to calibrate the UG so tried getting the EDS as a replacement. As others have reported - the EDS is a complete waste of money. It *does not* support trip computers or fuel economy (instant or otherwise) in my 2015GU. It's probably useful if you want to be able to clear or diagnose engine fault codes.
    I'm gonna give it to a guy I know who has a Prado. ;-)
    So - I went back and re-tried calibrating the Ultra Gauge. And after many hours of messing around I think I have it working right. It gives me what looks like sensible numbers that accord pretty closely to what I can calculate from pump litres squirted and km travelled on the ODO. It also does show a boost pressure - but until I install a grown-up boost gauge and Dawes I have no idea how accurate it is. It *looks* like it is a number that makes sense.
    So in short. I'd recommend a UG if you are prepared to put in some time to configure it.
    2015 GU ST 3.0CRD Auto Wagon, 2" EFS Lift, 5 x Procomp 16s with MT ATZ P3s, TJM Outback Bar and 12000lb Winch, 80l Sub Tank, Redarc 40A DC-DC with Optima Battery and 180w Solar, ARB Compressor On-board, 3" EXHAUST, Rhino Pioneer Platform and Darche Awning, DIY Drawers to come!
  9. #27
    Feb 2018
    Quote Originally Posted by GUDriver View Post
    HI,
    This post is a few yrs old, but still relevant.
    I have the same issue with my EDS on my 2008 GU. When I first started it up it ran ok, but after I ran the setup and entered the fuel type (and all other data) it gave me the *Not Supported* error.
    I will check back to share how it goes......
  10. #28
    Advanced Trav_1980's Avatar
    Feb 2019
    Albany,WA
    Bought the EDS, tried it, hated it, half the functions didn't work. Spend the extra $ and get ScanGauge 2, I did, haven't looked back! Worth the extra $
