Results 1 to 7 of 7
Thread: winch on dual battery system
    Sep 2013
    Portarlington Vic
    Lightbulb winch on dual battery system
    Hello there .
    My question is, to use the Aux battery or the car battery for my Warn 9000 winch?
    2012 GU Y61, Bull Bar, D/Lights, Alloy 1/2 rack, Warn winch, side steps,Snorkel, Remote coms / mobile & UHF,Dual batteries, set up for camper towing remote areas. nick name " Chuck "
    330 Post(s)
    Cranker mate. All other accessories to the second battery but winch to the starter. Your alternator will kick in as soon as you start winching.
    What MR said X 2
    Good rule of thumb with dual batteries where any type of isolator or charger is involved;
    -If it is an accessory that is usually operated with the engine running - wire to Cranker
    -If it is an accessory that is usually operated with the engine stopped - wire to Aux
    For a Winch the following also applies.
    -If you have no Isolator or a high current manual solenoid then it doesn't matter a terrible lot.
    -If you have VSR battery isolater wiring it Cranker means the Alternator etc stays in circuit because if you wire it to Aux the voltage drop when you run the winch will usually trip the Isolator and take the Cranker and Alternator out of circuit so they no longer load share.
    -If you have a DC/DC charger then you definitely want to be on the Cranker
  5. The Following User Says Thank You to the evil twin For This Useful Post:
    93patrol (21st December 2014)
    Sep 2013
    Portarlington Vic
    Thanks MudRunner.
    I think ill post more often.
  7. The Following User Says Thank You to barnelly For This Useful Post:
    MudRunnerTD (21st December 2014)
  8. #5
    Legendary 93patrol's Avatar
    Dec 2012
    Bunbury
    Great explanation guys I have been wondering for a bit how dual systems work with a single alternator
  9. #6
    175 Post(s)
    As others have said, winch always on cranker. Cranker battery is a sprinter and aux a long distance runner. Sprinter = more burst current which the winch needs.
    Sep 2013
    Portarlington Vic
    Thanks guys
    It's a simple one but if you don' ask no one will tell.
    Last week I also noticed discharge from near the TURBO had it checked and told pull it all out and clean! So far so good?
