Results 1 to 10 of 17
Thread: Tb42 carbie snorkel with dual battery
    Apr 2016
    Just wondering how different people have sorted out connecting their snorkel to intake with the dual battery in the way?
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Where is your second battery? Against the fire wall on passenger side?
    >>>tappin from tassie
    Hello from Under Down Under!
    Apr 2016
    It's over the wheel arch. Pretty much the same spot as factory batter but other side, and the area behind the strut tower is filled up with all that log goodness
    Aug 2011
    North West Tas
    56 Post(s)
    *LPG?
    >>>tappin from tassie
    Aug 2011
    North West Tas
    56 Post(s)
    Can you upload a photo? You may be able to relocate the LPG bits
    >>>tappin from tassie
    Apr 2016
    *LPG?
    >>>tappin from tassie
    yes lpg, cant imagine storing a log there would do any good
    ill post a pic shortly
  8. The Following User Says Thank You to Enthree For This Useful Post:
    taslucas (6th April 2016)
  9. #7
    Apr 2016
    heres the photos
    also do i need to have this section in the intake?
  10. #8
    Aug 2011
    North West Tas
    56 Post(s)
    Hmm that last pic looks like it might be some kind of air restriction for a cold engine? Is there anything attached to it? What does it look like inside?
    Mine doesn't have that bit, just flexible hose from the carby to the airbox which is where your second battery is.
    >>>tappin from tassie
  11. #9
    Apr 2016
    only thing attatched is a port from the exhaust manifold
    and on the inside there is a butterfly that looks like it lifts when the engine is running
  12. #10
    Aug 2011
    North West Tas
    56 Post(s)
    Ah yep that would be to direct warm air into the intake on cold start up. If it were me Id remove it when sorting out the snorkel. It is, after all, another hole water can get it.
    >>>tappin from tassie
