Results 1 to 6 of 6
Thread: V6 Navara diesel motor into a Patrol
    Nov 2014
    Hi All,
    Just putting it out there, has anybody put a 550 V6 navara motor into a GU patrol how does it go and what would a ball park dollar figure be.
    Also I heard along time ago that a LSD out of a navara would bolt straight into the front diff housing of a Patrol, if so would it be advisable
    Thanks,
    Mudman Patrol
    Patrol God Stropp's Avatar
    31 Post(s)
    Haven't heard of that but will be interesting to find out.
    Hell yeah that would be my choice , haven't heard anything in my travels.
    Keep checking the mags someone will do it.
    Most here including myself would opt for either an Auto or air locker in the front.
    I hear this all the time but dont know if its possible fitting front Navara diff into a GU
    43 Post(s)
    Give it a go. Anything is possible.
    But don't forget the gu has nearly a ton over the Ute. So the wicked up and go you get I'm the Ute will be some what lost
    462 Post(s)
    For the money and headaches I would do a TD42 conversion or if you want something different, chuck a Cummins in it. Getting it to fit may not be the issue but plumbing and wiring would be hell. Especially a late electronic motor like this into an older car.
    Would be interesting though...
    I have the write up here somewhere about the rear LSD..I'm pretty sure it was a pathfinder rear lsd fitted into the front diff in a GQ...was heaps of shimming and a lot of work...the bloke that did it wrote along the lines if you lots of time to tackle it yourself,or money and get someone else to do it....it was in a write up on 4wd action but way back in 09 me thinks..might try and find it oneday again and have a read through it
