Results 1 to 4 of 4
Thread: Clutch issues gq 4.2 injected
    Expert TJsGQ's Avatar
    Dec 2012
    Campbelltown, NSW
    G'day all..!
    So have lost all pedal for my clutch.. Can push all the way down and can't get into gear
    Have check the clutch reservoir and is empty.. Bought a new clutch a few months ago while
    I could get it cheap.. Am wondering if its the clutch gone or because of the empty clutch fluid
    If its something else..??? Any help would be great before I take her down to the mechanic to replace
    The clutch
    Thanks in advance
    Expert billyj's Avatar
    gordon
    if the clutch res is empty then you have a leak either at the master cylinder, the hose or slave cylinder doubt there would be anything wrong with the clutch it self. find and fix the leak, bleed the system and should be good to go
    Dec 2012
    Campbelltown, NSW
    Thanks for the advice.. Havin a look right now can tell u what probably caused it.. Bloody body lifts.. Thinking of gettin clutch replaced anyway as the rear mains gone.. Had a look looks to be the hoses coming off the small metal part on rhs of engine..! Just more reason to double check your hose lengths if your stupid enough like me and do a body lift lol..! Will let u know how I go..! Any advice on filling it up can I just pour it in or do I have to bleed..????
    Dec 2012
    Campbelltown, NSW
    Any one know how to get the rubber hose with crimped ends off
