5th December 2014, 10:19 AM
Advanced
TB42 Timing
Hey all, I ran a timing light on my TB42 carby running on petrol the other weekend and set it to 10 degrees advance, going off what I've read this sounded right? But now I've read that you should set the timing with the vacuum advance disconnected? I'd like to know where is it and how to go about disconnecting it for timing purposes, cheers!
1990 GQ Patrol High-Roof
Soon to be tourer!
5th December 2014 10:19 AM
5th December 2014, 10:43 AM
I'm not certain about disconnecting the vacuum advance when setting the timing but if you need to find it, the vacuum advance is the small black hose connected to the distributor.
Hello from Under Down Under!
The Following User Says Thank You to taslucas For This Useful Post:
WattsyGQ (5th December 2014)
