4th December 2014, 09:01 PM
Gu3-4 engines
Just trying to figure out, is the gu3 zd30 same as gu4 zd30? Then gu 5/6 has common rail?
I'm thinking of getting a 4or5 soon and I have a dp chip for gu3 zd30 I'm hoping to re-use on my next truck.
Thanks!
GQ Wagon 4.2 carb 4inch lift of the road resting
GU Rd28 Wagon 2 inch lift on the road now daily driver
D22 Navara ZD30- in rehab pending being moved on.
4th December 2014 09:01 PM
4th December 2014, 09:10 PM
Moderator
It should fit no problem mate, not sure if it will fit the CRD though?? Have a look at their website for part numbers and application.
Check out my Toy -->
Rogue Dung Beetle
4th December 2014, 10:30 PM
Hardcore
2007 was when they went to crd I think so gu 5? 2000 to 2003 was generally the grenade model zd30 2004 should be the go so late gu3 and gu 4 should have a zd30 that's better and they should be the same.
Whoever appeals to the law against his fellow man is either a fool or a coward.
Whoever cannot take care of themselves without that law is both.
For a wounded man shall say to his assailant,
'If I live, I will kill you. If I die, You are forgiven.'
Such is the rule of honour.
4th December 2014, 10:36 PM
I am he, fear me
90mav
Thanks!
Your chip is OK for a GU IV but won't fit a GU V or later.
If your budget permits I would try to find a ZD30 CRD rather than a Di tho.
8th December 2014, 10:08 PM
Patrol Guru
There are some GUIV's with the CRD engine. My 2007 DX is registered as a GUIV and definitely has the common rail engine.
Redbook lists GUIV, GU 5 and GU 6 as all being sold in 2007.
http://www.redbook.com.au/cars/resea...&eapi=2&Page=2
