Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Faulty interior lights
    Nov 2010
    Perth
    Hi I have a problem with the interior lights flashing on and off...12 moths ago I took it back to Nissan three times before they fixed it, only afer I said I wanted a refund on my extended wantanty.
    Extended waranty now run out ...and its back.
    I thought it was due to too much weight on the back door, however I have diconnected the switches from both back doors and its still happening?
    Any Ideas?
    Hi Brett and welcome to the forum could you pop over to the intros
    and tell us a bit about yourself etc before asking questions
    Just something the forum asks of us all polite and all, no harm done though
    you will get a better response too
  4. The Following User Says Thank You to threedogs For This Useful Post:
    Bigcol (2nd December 2014)
  5. #3
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Quote Originally Posted by Brett View Post
    Any Ideas?
    Mine occasionally does the same so I would be interested to find out how you solve this problem.
  6. #4
    Nov 2010
    Perth
    Apologies, I believe I have now introduced myself, but as I haven't used forums before I don't know if I put it in the right place?
  7. The Following User Says Thank You to Brett For This Useful Post:
    threedogs (3rd December 2014)
  8. #5
    The master farter
    mudski's Avatar
    461 Post(s)
    Well if you have disconneted the rear door switches, on both doors it would have to be one of the other doors doing it. Either that or the feed wire to one of the switches may be earthing somewhere.
  9. #6
    have you thought about a LED replacement, what about
    a small squirt on the contacts inside interior light especially the lever.
  10. #7
    Nov 2010
    Perth
    Cheers mudski, I guess I will disconnect all test and then one by one till I find it.
  11. #8
    The master farter
    mudski's Avatar
    461 Post(s)
    I had the same issue and found the large barn door switch was the culprit. Some re adjustments to the catch to make the door shut tighter and was all good.
  12. #9
    Nov 2010
    Perth
    Cheers threedogs, but this occurs with the doors shut while driving and light coming on not doors open lights going off. The lever/switch operates as it should. And both lights flash on and off simultaneously.
  13. #10
    The master farter
    mudski's Avatar
    461 Post(s)
    Definately a switch issue I think.
