2nd March 2015, 09:33 AM
#21
mudski
Save your coin and get the HPD high flow maf housing and air box lid. No need to worry about limp mode ever again. My boost gauge is to 30psi. Just as a test I wound the dawes right in. I had the needle on the boost gauge off the clock and I still saw no limp mode. But the engine light came on... jeez it went though.
Done the same as above, always had some form of limp no matter what I done as in would be good for awhile but then a random limp now and then, would be good then a cold evening and then limp at 3000rpm ect or upon harder than normal acceleration and limp on gear change, ended up doing my head in, put HPD MAF housing and airbox lid on and no limp ever again, did loose a bit power down low, put a chip in now it goes pretty good, still dialling it in a little.
I've wondered if you could just shave the inside of the standard MAF housing on a lathe and achieve similar results, I mean something like .30 tho of it, as doesn't the standard MAF housing narrow slightly in the centre of the housing to speed up the air flow past the MAF sensor, so making it straight through instead of narrowing could work? Would only be a smidge of and a cheaper option than HPD>
02 GU ZD30 Auto, NADS, Setting up for touring and camping, Best thing is the missus loves driving it to..
2nd March 2015 09:33 AM
2nd March 2015, 11:16 AM
#22
SG1
Id be interested in this, I also read there is an air box mod you can do yourself as well.
Maybe one of those finger files could remove some material [power file]
2nd March 2015, 03:03 PM
#23
the evil twin
... are their Boost Controllers any good Mudski?
I've actually got one here. Good design but the fine control is pretty shite. I was thinking of bringing in cheaper needle valves to compete with these and other cheaper needle valves being sold, as the Tognella ones I have, although they are made really well and the fine control is really good for adjusting the spool up, they are top end in price. But I can see it creating more issues than its worth. So it has been left at a thought...
the evil twin (2nd March 2015)
2nd March 2015, 03:10 PM
#24
SG1
First you'd have to find someone who can shave out 30thou or so in the housing. Being plastic I would be too concerned of it collapsing. Second if it didn't work, you would have lost your coin on paying someone to machine the housing out...
threedogs
Ahh yes. I attempted it. Well sort of. I bought the necessary parts for the mod. And got the cbf's and though if I didn't do it right I'm stuffed. So I bought the HPD lid aswell as the HPD housing.
3rd March 2015, 01:30 PM
#25
From all the discussion, it seems that the EGR blank is not really the issue. As I read it, changes to the air flow pattern causes the MAF to tell the computer to shut down for a second. That reasoning is supported by the advice to adjust the needle valve, causing different spool up rates (and consequently different air flows).
I don't see any relationship between MAF readings, and the intake manifold--UNLESS the EGR solenoid somehow opens under hard acceleration and changes air flow,
I can't find anything in my Gregory's manual, and it is fairly detailed.
Unless I find a better solution, I am going with a $???? HPDiesel housing and air box.
Comments on my "logic" (or not)
MAF sensor fitting $250, Air box lid $395 Need to quit drinking for a week!!!
Reason: New information
3rd March 2015, 05:25 PM
#26
mudski
Still not convinced it couldn work, a bore hone on a drill press or a round buffing/sanding of same size as MAF housing may work also, A lathe may struggle the more I think about it and possibly take a bit much of, look at the way the HPD maf housing is, it actually enlarges slightly around where the MAF sensor goes to slow down the speed of the air travelling past the MAF sensor, maybe even to much and as they state allows 30% more airflow through with out the MAF sensor sensing it, its just tricking the MAF sensor is all its doing, the standard MAF housing slightly reduces in size around where the MAF sensor goes to speed up the air flow past the maf, take away that and the air flow slows down, maf voltages are slightly lower, less limp mode. The thickness of the standards MAF housing shouldn be and issue as its not like your halving it or anything like that and no cracking of the housing should happen, maybe if you wanted it like the HPD you could let your your bore hone or round sanding/buffing do a few more rotations where the maf sensor goes and enlarher it slightly, all we are talking is a hair width.
Nearly tempted to go do and see if it could work as in theory its no different than the HPD MAF housing for $250, I think it would work with care taken and worse case if it doesn't then you were probably in the market for HPD one anyway if needed.
3rd March 2015, 05:38 PM
#27
SG1
If you have access to these tools then yeah it may work. But most don't, including myself. Hence forking out the coin....lol. but if it could be done. Your Larfin!
3rd March 2015, 05:47 PM
#28
I do like the Bling the factor of the HPD maf housing and airbox lid, just thinking out loud and if any one tries it don't blame me if doesn't work, I found the hardest part was undoing the standard maf housing from the standard lid as the nuts spun and broke the plastic retaining clips on mine when I changed to the HPD, was kinda spewing about that but in saying all this I am happy with the HPD products but as said just thinking out loud and may work or help someone brave enough to try.
3rd March 2015, 06:54 PM
#29
SG1
Haha. So did mine....
3rd March 2015, 08:03 PM
#30
I am he, fear me
Dr Gary
snip...
The MAF has two sensing elements.
1 x Air temp
1 x Air flow.
The ECU figures out the air mass (amongst other things) by the change in static and dynamic temps across the thermistors, charge air pressure, EGR position etc.
Not 100% sure what you mean by 'I don't see any relationship between MAF readings, and the intake manifold'
The EGR is fully closed under hard acceleration of (IIRC) 70% throttle or higher and won't open unless something is screwed
AFAIK the Di's are driven by a stepper, the CRDs by a closed loop control... but... there are also schematics around of ZD30's with some sort of weird arse vacuum control.
I haven't seen an Aussie one like that but I have only screwed around with a couple of early CRD's.
The Following 2 Users Say Thank You to the evil twin For This Useful Post:
Dr Gary (4th March 2015), mudski (3rd March 2015)
