I must say although these gauges are awesome and intimidating, I would love to have more modernish HUD stuff to monitor 4 temperatures and two pressures as they are distracting as well.
I've always wanted to do a custom display with the following, and may do so one day when I work out what will work with the tb48 (apparently NOT OBDII).
I have 9 gauges in a 3 pod pillar mount
Batt1 / Batt2 / Amps
EGT / Boost / cabin temp
Oil Pressure / Water Temp / Under bonnet temp
cleared a heap off my dash, and all are easy to read with a glance
if its blue - no problem
if its RED - problem..........
A another option is o use a ardunio board, write your own software to monitor your snesors
I have a 2 line lcd display sitting just in front / at the base of the taco that displays battery voltage, cabin temp, LPG gas level and estimated LPG range
Sounds very interesting!
However the Turbo gauge has a mechanical input rather than electrical?
