Page 10 of 10 FirstFirst ... 8910
Results 91 to 93 of 93
Thread: roof rack problems
  1. #91
    Ok need some ideas for my awning light and not led strip lights, I think it can be done better.
    Im thinking 8 LED cree DRL with a dimmer., I saw BA had a led work light
    shining sideways so any pics would be great, it will mounted where the eye nut is
    Maryborough Qld
    Threedogs, any luck with your led light. I used to have one but it was portable, I had it attached to an right angle bracket and this just slotted into a raised piece of 25 x 3mm piece of ally flat that was screwed to the inside of my roof basket. Probably more importantly any more info on your spare wheel lifter?
  4. #93
    Quote Originally Posted by gregs View Post
    I.ve decided on this 18 watt die cast alloy one from Kawell.
    It has a 60 degree beam which Ill wire via a dimmer and remote control
    about 200mm long
