4th March 2011, 08:27 PM
Typical Oil Pressure Gauge Reading
Hi people,
Just wondering what your generic oil pressure gauge reads in normal travel? Mine hangs around 4.
4th March 2011 08:27 PM
4th March 2011, 09:43 PM
Administrator
GQ, MQ or GU?
My GQ stays around 4 too but is very unreliable and can drop to "1 or 0" for long lengths of time.
5th March 2011, 02:58 PM
AB
GQ, MQ or GU?
Sorry, it's a GQ 2.8 td.
5th March 2011, 03:25 PM
Dribble Master
My 4.2EFi GQ tends to hang around the 4 mark...... sometimes a little higher, sometimes a little lower
6th March 2011, 08:27 AM
Moderator
If you whack an after market on you will realise how irrelevant the Genuine one is. Just like you Water Temp gauge, both the Water Temp and the Oil Pressure move a round quite a bit depending on what you are doing and how you are driving the car. Both the Factory gauges have a big flat spot built into them that takes up the minor movement during operation so you guys dont freak out.
Go the after Market gauges for sure.
Check out my Toy -->
Rogue Dung Beetle
7th March 2011, 12:22 AM
Dribble Master
so with an aftermarket one, what sort of pressure should you be reading? and do you usually just replace the stock dials or fit new ones on a pod or something?
7th March 2011, 12:23 AM
get rid of the old one`s and replace from sender to gauge
then nowoolies lmao
HELL NO !!!!!!
The Following User Says Thank You to nowoolies For This Useful Post:
7th March 2011, 12:25 AM
Dribble Master
nowoolies
then nowoolies lmao
cheers mate
7th March 2011, 08:29 AM
One thing Nissan didn't seem to get right is gauge quality, my (TD4.2) like most 0-4 irrespective of oil condition or temp
7th March 2011, 08:57 PM
Even if the guage is dodgy if it has consistent behaviour matching the way you are driving then it is probably telling you something right? Mine sits on 4 regardless of how I hard / soft I drive but t falls to 1 when idling. Climbs back to 4 when I accelerate from idle.
I've often wondered if low pressure from idle restricts bottom end grunt?
GQ Safari 2.8TD. BFG AT's / Safari Snorkel / Straight thru exhaust / Lots of electrical mods
