23rd November 2014, 08:03 AM
ZD30 CR Rebuild or Conversion?
just run into trouble with my 2008 ZD30 Common Rail, such that it needs to come out to be fixed.
is it worth swapping it for a TD42 Turbo?
what is the deal about emissions?
does any one know what its worth either way (rebuilt ZD30 CR, TD42 Turbo, or new crate ZD30 CR)
have spotted a ZD30 CR with 5 speed box attached in WA for $5000 on E bay 30,000Km on the clock maybe this is the way to go? not sure if its got warranty though??
my ZD30 has been flogged but was still running ok, just snapped off half of the exhaust manifold studs in the head.
BTW I was using around 20L /100km with about 50/50 split Hwy/Town so there is obviously something else wrong, hence my decision to remove it.
23rd November 2014 08:03 AM
23rd November 2014, 08:32 AM
Fix the exhaust and sell it as is, and get newer one ? Were you upgrading the exhaust or the stock was buster?
23rd November 2014, 09:52 AM
four of the original studs snapped off and left threads behind, which resulted in manifold leaking, which I thought would be easy to fix till I found 4 snapped, not just loose, like I had hoped .
23rd November 2014, 02:31 PM
I am he, fear me
You won't be able to fit a stock TD42 to an 08' Series patrol and get a legal mod plate
If it has been flogged enough to have broken 4 exhaust studs and be using 20 LPH I would be fitting another engine if I was keeping it or maybe a reco head if I was selling it.
Scottch (23rd November 2014)
23rd November 2014, 04:13 PM
is it difficult to remove the engine and transmission in one piece?
is it a done thing?
23rd November 2014, 05:57 PM
the evil twin
You won't be able to fit a TD42 to an 08' Series patrol and get a legal mod plate
I have heard 50/50 on this. I don't know if it differs from state to state. But when I was doing some homework on doing a 4.2 conversion, I was told a definite no. So that ended that. I'm stuck with the grenade.
But then I've been told that some of our local 4x4 workshops like Readies and 4x4 obsession, do the conversion and engineer everything. I haven't talk to them about it, so don't know how much truth there is to that.
To the OP. A straight swap like for like, will always be cheaper than doing a conversion to something else.
23rd November 2014, 07:06 PM
the evil twin
I noticed you changed it to say "stock", so you mean a TD42 could be tricked up to spec for emissions???
23rd November 2014, 09:20 PM
I have also read somewhere that someone was doing the td42 conversion(all engineered) for crd models but can't find where i read it.
2008 GU6 ST 3.0 CRD Auto, 2" Lift, ARB Bullbar, IPF Spotties, Side Steps, Maxxis 980 A/T, Roof Rack.....................
23rd November 2014, 09:21 PM
I am he, fear me
The simple answer is you can fit anything to anything... if you have the money and someone to sign off on it.
To fit a TD42 to a late series GU, where the TD42 was not a factory option, you need the modifcation to comply with ADR's etc but the big stumbling block is emissions regs.
The TD42 was discontinued for several reasons but emission compliance issues was one of them.
To pass the emissions regs you need the vehicle modified before it can be tested and signed off.
If you can't get the signoff then you are out big bucks.
I don't know of anyone doing CRD to TD42T mods and I haven't ever seen one for sale or the service advertsied but Hodge may well be correct and someone may be doing them.
24th November 2014, 08:11 AM
quite simply no to the 4.2 motor
07 crd,,bridgestone 697lt, 2.75 buedesert ex,
SOLD theres a lot of my blood, sweat and money in that troll.
92 gq ti tb42efi my brothers gq extractors dual batteries brake controller uhf alloy bullbar
SOLD with a heavy heart but gone to a nice young fella
13 y62 the beast that burbles
