Hey just signed up having problems with my 2002 gu zd30 the engine light keeps coming on.. the turbo seals went earlier in the year, got the turbo replaced and Nissan replace most of the sensors, I've blocked the egr, the engine light has started coming on again. I have a Dawes valve and boost gauge to be fitted this weekend , is there any other mods I should be doing ? Any help would be very helpful.
I went to download a manualbut can't as I'm to new to the site
Hi Jack dis connect to battery for a while see if that helps.
but in the mean time pop over as suggested to the intros
you will get a better response, I dont think the manual would help with this problem
ok sounds like you need to disconnect the battery for half hr or so to reset the ecu and then it will be playing with the boost to make sure you are not overboosting the engine.
Might want to swap your ign relay [blue] with the aircon relay for a test[Blue]
Photo are in a thread with similar problems, also poor earths are a curse of all GQs and GUs
boost is a tad low IMO but all motors are different, would prefer it up another 2 or 3 lbs
ign relay is on the left
