Results 1 to 5 of 5
Thread: Rear drivers side window
    Nov 2014
    I've only had my 1998 GU patrol for about a week and noticed all the window work except the rear drivers side window. It doesn't operate from either the driver window console or on the rear window switch. Where do I start ? Much appreciated
    Sep 2011
    adelaide
    18 Post(s)
    G`day Simon
    Can you hear the drive when you try to wind it up or down?
    If you can hear the drive its a mechanical fault with the winder mech, if no noise then it will be electrical
    Either way it`s most probably in the door, thats where I`d start .
  4. The Following User Says Thank You to pearcey For This Useful Post:
    Simon H (19th November 2014)
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Try swapping the drivers side rear door switch with the switch from the passengers rear door .
  6. The Following User Says Thank You to Yendor For This Useful Post:
  7. #4
    Nov 2014
    There is no noises what so ever so I will pull the door apart and have a look.
  8. #5
    Nov 2010
    Getting a life...
    38 Post(s)
    You'll probably find it's the switches. Pull them out and clean them. One of my back ones dont work, The switch itself fell into a million pieces when I pulled it out. But I dont sit in the back, so I havent replaced it. They are not cheap. Even for second hand ones.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  9. The Following User Says Thank You to katwoman For This Useful Post:
    Simon H (22nd November 2014)
