Results 1 to 10 of 11
Thread: Rear brake light clips
    Nov 2014
    Hi all
    I'm a newby to this forum and can't download a manual yet and have run into a problem.
    My right hand side brake light isn't working and I have undone the two screws and pulled it apart. I can get to the globe to replace it but have found 4 clips and don't know where they go for re installation. Where do these clips go ?ny help would be great and a photo from a manual would be awesome. Thanks in advance !!
    Hi Simon, best to take a photo of what you mean bud. You will get an answer much quicker I reckon.
    Also I take it, it's the rear quarter light, not the lower bumper light.
    Nov 2014
    Hi mudski I meant the lower bumper brake light. Pulled it out and found 4 clips and don't know where they clip. Thanks
    Are they a flat, rectangular shaped clip with a slot in the middle?
    Nov 2014
    image.jpg it is rectangular with a slot in the middle. Took a photo but won't upload
    I can see the clips. Now the plastic surround the houses the tail light has four tags on it. These tags slips through a little slot on the bumper itself and then these clips go on the inside of the bumper and slide onto the tag. A lot of Patrols don't have them as they simply fall off. Mine have never been there and I have two springs, like an accelerator return spring, that holds the lights in place.
    Simon H (12th November 2014)
  9. #7
    Nov 2014
    Thank you very much mudski I have realised what I have to do now. The plastic surround was loose on the top and now I can replace it with clips to hold in place. Once again thanks
  10. #8
    Quote Originally Posted by Simon H View Post
    Too easy mate. Does your light have the two springs behind there too?
  11. #9
    Nov 2014
    No not that I have seen but will have another look tomorrow
  12. #10
    No worries. I think because I don't have those clips, I have these springs instead. Makes it easier when removing the lights though. Just unclip the spring 8 either end and the light falls out.
