20th November 2014, 07:38 AM
#11
Hi Snowy,
I am interested in a Scan gauge as well for ALL my problems.
Where from and what model did you get - looking at flea bay there are numerous and they confuse the L out of me.
Tx,
Shane
20th November 2014 07:38 AM
20th November 2014, 09:11 AM
#12
Beucam
Hi Snowy,
Tx,
Shane
What model GU do you have? As the earlier GU's can only use a device called ECU talk. Depending on if you have the OBDII plug or not. But if the Scan Gauge is what your after I think its the Scan Gauge II you want... I'm sure others here will be able to clarify this.
20th November 2014, 09:34 AM
#13
Hi Mudski,
I have the 2003, 3.0lt Diesel GU Patrol, and yes it has the OBD2 plug.
Looking around have seen the ELM327 wifi units which plug into the OBD2 plug, then you down load Torque app onto mobile and you can see and set / reset MIL faults. Any body had any experience with these units.
I already have a Boost and Pyro gauge, only would like to scan and understand faults.
Tx,
SHane
20th November 2014, 04:22 PM
#14
Gday Beucam
I got a Scangauge E not the II have a look at www.scangauge.com.au. Then goes to a company call Ample Outdoors in Lithgow NSW. Ordered it Thursday night , in the mailbox Monday morning 130 dolla, cheaper than evilbay. The E gave me the Trip computer I wanted plus will tell you what faults are on the ECU and will reset them for you. It has more than enough features for me. I did think about the II but it came down to $$$$. Have a look at the instruction booklet which you can download from the scan gauge site (http://scangauge.com.au/user-manuals/ ) to see if you want the extra features of the II over the E. Haven't used the other things that you mention. I was more into the ability of the scan gauge to be a trip computer as well once all the ECU setting was done. He he he can tell now if Wifey pulls toooo many revs in the Troll.....
2008 Patrol 3.0L 2" Raw Nitro Lift, Polyair airbags, Airflow snorkel, Drawers, UHF, Dual battery system and cage scavenged from my Prado Alloy roof basket from the chookyard. Boost and EGT gauges and NADS
1980 MQ Ute (nearly forgot the indestructible farm Ute)
20th November 2014, 05:14 PM
#15
I am he, fear me
Beucam
Hi Mudski,
Tx,
SHane
AFAIK none of the OBD11 tools work on the Di's.
The Di's have the OBD11 plug but they aren't a fully OBD11 compliant system.
Scangauge certainly doesn't work.
I know that ECUtalk does but not sure of any others
The Following User Says Thank You to the evil twin For This Useful Post:
Snow Patrol (20th November 2014)
