Results 1 to 10 of 13
Thread: Patrol GU Heavy Steering Feel
    Sep 2014
    Hi Guys. I noticed that my Patrol has a heavy steering feel compared to others. I'm running stock tires. any comments from the patrol gurus?
    Western suburbs of Melbourne
    11 Post(s)
    Quote Originally Posted by Zhing1 View Post
    can you give us any more details of what is happening or why you think its heavy. Or is it just stiffer when turning the steering wheel
    Sep 2014
    Hi. It's just a very heavy sensation. Doing a u- turn takes an effort. The power steering pump seems okay. No weird noise emanating from there. There are no leaks on the power steering system. What do you guys think?
    check your tyre pressures minimum 35psi around town
    Sep 2014
    Did that. Still the same. Do does the return to center damper have anything to do with this?
    Probably.....
    What NN said ^^^^^
    Jack the front diff and try it with and without the RTC damper connected
    By turning the wheel the spring on the RTC damper is fighting against you to RTC.
    every time you turn the wheel it wants to return to the centre, hope it makes sense
    great having all the info
  10. #9
    snip...
    Agree, TD ;-)
    Zhing1...
    Just curious, why are you running an RTC on a vehicle with stock tyres and I assume little to no lift?
    I dislike RTC at the best of times so freely admit I am biased.
    Was the RTC fitted to try and stop the dreaded 80 KPH shakes?
    If it was, you are much better off finding out what is screwed (panhard bushes or whtever) and fixing the cause
  11. #10
    what ET said x2
    RTC are not my cup of tea and of all the ppl I know in the 4x4 game I cant think of anyone who has one.
    If it is only to mask the dreaded 80k wobble your better off fitting a quality steering damper and finding and fixing your wobble
