12th November 2014, 10:50 PM
3 gas tanks.... Help please!!!
I have recently purchased a 02 patrol dual fuel, 4.8 ltr.
I have noticed there is 3 small gas tanks , but it's only filling one when I fill up..
Apparently there is a switch which will change and fill all tanks,
Does anyone know what this switch looks like? I'm really confused :/
Any help would be appreciated, thanks all!
12th November 2014 10:50 PM
13th November 2014, 08:18 AM
I've not seen that setup so there may be no joy here. Find a good lpg mechanic to sort it out, your going to need one anyway
Any idea of the size of the tanks? I've got a single 120L tank replacing the original main track which is more standard.
Cheers.
13th November 2014, 08:25 AM
you may have sill tanks , the switch could be a small rocker style with some led lights to show the tank statis
13th November 2014, 03:18 PM
i have seen those tanks but you will need to search and follow the wiring to find where the switch is, it could be anywhere.
13th November 2014, 04:15 PM
Apprentices Rule!!!
It's not that the 3 tanks are hooked up in series? I.e the three small tanks are really just one big tank? Most setups I have seen are like this, and only use multiple tanks because it is easier to position them where they won't be damaged
13th November 2014, 08:39 PM
Are theyt scuba type tanks as per punderhead.
see http://www.ebay.com.au/itm/FORD-FALC...item339875c61e
How many liters is the tank taking?
