Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: nissan patrol y61 engine swap with mercedes om606 3.0l turbo diesel
    Hardcore 2TROLLFAM's Avatar
    Nov 2011
    Chuwar - Ipswich - QLD
    Welcome to the forum!! These guys (and girls) are a wealth of knowledge - me not so much LOL
    I come to socialise and read through all the threads for interesting tid bits. Pretty much everything is covered but the best part is you're not made to feel stupid for asking questions
    Hope you enjoy your stay & become part of this awesome community !!
    NISSANS Rulz .... "Amelia" the 2006 4.2ltr Patrol Ute & "Seamus" the 2008 3ltr Patrol Wagon
    Oct 2014
    london, England
    wow...thanx alot guys... i sense a lot of love in the air...lol.. finding duramax in uk???????? lol.. thanks alot for the link.. guess i may have to go down the NADS route then... and then upgrade the intercooler to bigger size ie 450 x 300 and mount it in front of the radiator? block off the egr, egt gauge, Dawes valve and a Needle valve, boost gauge, exhaust upgrade to 3" custom mandrel bent, remove cat converter???, vent the crank case pipe to open instead of a catch can??? and spear MAF 2 more like it...anything else i should consider? from reading the forum, am i correct in understanding i should shop for post 2003 model? thanks guys really appreciate the feed back.. one love to you guys
  4. #13
    welcome aboard mate,enjoy
  5. #14
    Advanced heaths_gu's Avatar
    Oct 2014
    Bathurst
    Welcome to the forum mate
  6. #15
    Oct 2014
    london, England
    722.6 bellhousing.jpgnissanRE4R03Aimages.jpgnissanRE4R03Aimages2.jpg hiya guys. i apologise but am still looking into the OM606 engine swap before am beaten into the NADS solution. the 1st pictures is the bellhousing of the the mercedes engine/gearbox and the 2nd and 3rd pictures are for the nissan transmission pump and nissan bellhousing respectively. so you can understand why i think it should be a simple"ish" swap.
  7. #16
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Having done engine swaps in the past the gear box adaptor is the simple part. Engine mounts, wiring, computer, fuel, air, exhaust, radiator, clearance - the list goes on. There is nothing "simple" about any engine swap. If you are still determined this is the mob I sourced a lot of parts and adaptors through.
    http://www.marks4wd.com/
    Good luck
  8. #17
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    Welcome to the forum.
    If it was my vehicle, for piece of mind, I would get the engine thoroughly checked out. I would do a compression test, get a mechanic that has an inspection camera to check the piston tops and bores. Also I'd check that the intake manifold hasn't gummed up with soot from the EGR valve. That way you know that the engine is worth fitting NADS to or if an engine swap is necessary.
Tags for this Thread
