8th November 2014, 09:39 AM
Cleaning Aux Fuel tank
Hi All,
Pulled out my aux tank and found a layer of rusty crud on the bottom. Natrad offered to clean the tank for between $250 and $500, still better than the $1100 for a new one. They claim they cut holes in it to access all areas with a steam cleaner, then seal up. Has anyone had any experience with cleaning tanks, does it work? Any other suggestions?
8th November 2014 09:39 AM
8th November 2014, 01:45 PM
Fark. Forget that. Why would you cut holes in a perfectly good tank and risk it leaking??
Remove the sender unit. It's a 100+mm hole. You'll easily get in there to clean it.
See if any of your mates have hot water high pressure cleaner and dig in.
If it's bad scrap and scrub first.
9th November 2014, 02:18 PM
have opened it up through sender and found baffles on both sides, can only access a small area.
9th November 2014, 02:32 PM
I'd take advantage of this Opportunity to upgrade to a long range tank that's 250-500 bucks towards a new one...
9th November 2014, 04:44 PM
Thanks for responses!
Have a long ranger main tank, but was hoping to save aux tank. Will give the electrolysis a go, could take a while but then have nothing to loose. Will set up power supply in the yard and an iron electrode and see how long it takes to clean.
9th November 2014, 04:51 PM
The 747
biggqwesty
No chance mate... There is very small amount of the tank you can clean, there are baffles in the way.
Mine had a little bit of surface rust and I scrubbed what I could with petrol but for the rest I just put a little bit of petrol in the bottom and swirled it around like a mad man. I did that several times and then once the tank was in the car I put a bit of petrol in it and went for a drive around the hills, got home and drained it. I just put a good filter on the tank and won't have any problems.
9th November 2014, 05:19 PM
I've had about 3 tanks cleaned that had rust in them, they not only pressure test them but also acid dip and treat the steel with some thing that I can describe as an anti rust coating, sort of like a galvanising coating. If you add the cost of the chemicals and the labour involved that price isn't that much if you take all that into account
11th November 2014, 09:09 PM
Thanks Alitis007
Who cleaned your tanks?
11th November 2014, 09:22 PM
You can buy diy kits, not done it myself but cheaper than a new tank http://www.kbs-coatings.com.au/produ...nk-sealer-kit/
The Following User Says Thank You to megatexture For This Useful Post:
mudski (14th November 2014)
14th November 2014, 09:43 AM
$250.00 to clean a tank?? Why?
Just swill some diesel around, empty and repeat several times, leave it upside down to dry out thoroughly.
Make sure you use your aux tank every fill, know of people who only use theirs for long trips and of course condensation forms in the tank followed by rust.
Keep it full of diesel and regular filter changes.
Fitted a water trap to my ute after several bad experiences with watered diesel at outback fuel stops.
Hard to believe they cut holes in tanks and the unsuspecting wallets.
