Results 1 to 10 of 13
Thread: Help! Where does the plug go? 4.2TD S3
    Feb 2012
    Lakes Entrance
    Hi guys.
    Gonna have to ask. Been scratching my head for a while.
    Putting my GU back together having had the inj pump out. There's a plug I can find the socket for.
    The harness has the grey single wire plug going to the oil pressure switch. At the same point that leaves the harness there's a short (5-6") lead going to a two pin black plug of the same type as the grey oil pressure one.
    I've been scratching my head for a while now and can't find where it goes.
    Help appreciated.
    I'd post a pic but not sure how to do it from my iphone.
    Dave
    330 Post(s)
    There are quite a few generic plugs that float around and not in use.
    Use a forum App like Motorculture and upload from your phone mate.
    Feb 2012
    Lakes Entrance
    This one's been in use. Spotless inside. Anything that has been just floating around in my Gu has long been turned a brown/red desert mud colour.
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    What colour are the wires? are they small or large size wires?
    Feb 2012
    Lakes Entrance
    Hi Yendor,
    Thanks. Small wires WHITE & BLUE/WHITE (stripe).
    Sorry I hadn't posted pic earlier. Couldn't find motor culture in the app store and Tapatalk doesn't give me access to this forum that I can see..
    Dave
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Is it long enough to reach the injector pump? Is the other half of the plug on the bottom of the injector pump?
  8. #7
    Feb 2012
    Lakes Entrance
    Hi Yendor,
    As far as I can see there's only one plug on the injector pump. Not sure that this would reach anyway but I can take a look.
    There's a plug on the side of the injector pump with three wires that fed the black box for NATS (which is what I was getting rid of,) but that's a three pin plug.
    Is there another plug on the injector pump that you're referring to?
    DJ
  9. #8
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Quote Originally Posted by davejones View Post
    Hi Yendor,
    DJ
    Yes on the bottom of the pump.
    Have you changed injector pumps?
  10. The Following User Says Thank You to Yendor For This Useful Post:
    davejones (8th November 2014)
  11. #9
    Feb 2012
    Lakes Entrance
    Out in the shed now. I'll have a look. No. Same pump. Might PM you my phone no if I don't find it in next few mins.
  12. #10
    Feb 2012
    Lakes Entrance
    Mate. You're a bloody legend. Hiding above the engine mount.
    Thought I'd looked everywhere.
    Probably means I didn't have to do any of the stuff I spent all day in the shed doing yesterday.
    That was the source of the injector pump timing fault code I'm guessing, and it doesn't need the NATS module at all.
    I'll write up my NATS removal now that I've got that sorted. 😄
    Dave
