7th November 2014, 12:02 AM
2in lift, 3in shocks?
Hey guys,
I have a GU 2in lift in my GQ, the springs are HD and i've stuffed a shock so i'm thinking of getting 3in shocks instead of the 2in ones.
Will I have to extend brake lines and will I have to worry about springs falling out?
Any assistance is appreciated as I have to make a decision pretty quick.
7th November 2014 12:02 AM
7th November 2014, 12:20 AM
Legendary
You can probably get away with the standard brake lines by slightly extending the mounting bracket on the diff. I made up a spacer bracket till I got a custom braided line made up, and it was fine.
As a permanent solution though, I had a braided line made up for around 60 dollars ..... cheap insurance
What is the extended length of the longer 3 inch lift shocks to the 2 inch lift?
Mic
Hardcore
Should be fine and won't need to change anything.
Whoever appeals to the law against his fellow man is either a fool or a coward.
Whoever cannot take care of themselves without that law is both.
For a wounded man shall say to his assailant,
'If I live, I will kill you. If I die, You are forgiven.'
Such is the rule of honour.
7th November 2014, 12:22 AM
Legendary
Springs wont fall out either with only a small increase in extended length
7th November 2014, 09:01 AM
front and rear measurements as it sits now are F- 490mm and R- 570mm.
10th December 2014, 10:35 AM
Did you notice any differences between the 2 inch shock compared to the 3 inch
10th December 2014, 11:08 AM
I sure did notice a difference, i've had to lengthen brake lines. As for flex, yes a noticeable difference especially with front sway bar removed. Problem is different brand shocks have such different travel lengths etc, I ended up with Raw ones due to the amount the extended compared to others, I was going the ProComp ones but guy reckons I couldn't do it so I went elsewhere.
