Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Shelf Life of Oils and Brake Fluids.
    Advanced
    Sep 2014
    Hi Guys. Any Lubricants expert out there? I have around 10 liters of 10w40 fully synthetic oil as 1 liter of DOT5 brake fluid that was on stock for 4 years. All of them are sealed and we're placed in a dry storage space. Can any one tell me if I can still use them on my rig? Thanks.
    Advanced
    Sep 2014
    Come on guys. No one insights on this?
    Legendary my third 256's Avatar
    Aug 2010
    adelaide
    oil should be ok patrol gu's use dot 3
    2007 GU 6 /ST-L / MYO8 / DIESEL/AUTO /MOONSTONE /pro vent 200
    OH LEATHER IS NICE
    330 Post(s)
    If they are sealed they should be fine. I would use it.
  6. #5
    Advanced
    Sep 2014
    Will there be issues if I used DOT5 instead of DOT5 on my rig?
  7. #6
    Quote Originally Posted by Zhing1 View Post
    No there won't be issues if you used DOT5 instead of DOT5, as long as your vehicle specifies the use of DOT5, then DOT5 can be used......... Otherwise you might need to use something that isn't DOT5
  8. #7
    Advanced
    Sep 2014
    Haha. I meant using DOT5 instead of DOT3.
  9. #8
    Aug 2010
    adelaide
    on top of the brake fluid cap on the master cylinder is written your answer dot 3
    they are different thicknesses and compress at a different rate
    OH LEATHER IS NICE
  10. #9
    Advanced
    Sep 2014
    I also found a gallon of engine coolant that's 5 years old. Is this still okay?
  11. #10
    Advanced
    Sep 2014
    So I can't use DOT5 on my rig because it only specifies DOT3? I was under the impression that the higher DOT rating, the better. What could go wrong if it pushed thru on using DOT3?
