Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: $7867 - $9160
    Expert Gary Vansleve's Avatar
    Sep 2013
    Brisbane
    $7867 - $9160
    Did that get ya attention ??
    Been thinkin about fittin 35"s to my 06 ute. This is what I figure its gunna cost me to fit.
    Do you think it's worth it ?
    [/SIGPIC]The old girl like me well past the use by date
    Nope. Not for that price!
    brisbane
    Why so much ?
    WA Wheatbelt
    23 Post(s)
    Is that for the 4 corners and a spare or two or three?
    Hope they're throwing in the taxi fare for you to pick it up when they're finished.
  6. #5
    Quote Originally Posted by DX grunt View Post
    I'd expect a return flight airticket for that..... In business class
  7. #6
    Sep 2013
    Brisbane
    Quote Originally Posted by megatexture View Post
    Why so much ?
    Well ok here goes.
    Figure I need 4.6 gear set. Then seeing that I am going to pull the centres I thought may as well fit lockers. Then will need to buy correct offset rims and tyres. Seeing that lockers and gear set will be fitted need to find someone with the expertise to set the centres up so factor in some labour costs. Last but not least will need a quality air compressor.
    Why the compressor you ask. Well to fit a 35 where I want I will need to air down the tyre so it fits in the space allocated.
    Is it worth it seems pure indulgence on my part.
    NB the ute is being set up as a tough tourer towin a 2 tonne offroad van.
  8. #7
    Hardcore macca86's Avatar
    Jun 2011
    Brisbane again! whoo!
    If you have 4.1 or 4.3 diff gears I'll take them off you if you like. You don't need 4.6 gears better off with transfer case reduction gears. As for lockers you only need a front one really.
    Whoever appeals to the law against his fellow man is either a fool or a coward.
    Whoever cannot take care of themselves without that law is both.
    For a wounded man shall say to his assailant,
    'If I live, I will kill you. If I die, You are forgiven.'
    Such is the rule of honour.
  9. #8
    W.A. (wandering aust)
    I had 35's on a TD42 with 4.6 centres on a prev rig and if you are going to tow 2,000 KG's with the 35's on then you will def want 4.6 diffs
    Agree with macca in that I would only lock the front and reshim the LSD if needed.
    I have onboard air with a reasonable sized tank on my current ute and it is really handy with the 35's
  10. #9
    Sep 2013
    Brisbane
    Yep I agree. The ute puts out 110 killowats at the rear at the moment. Recently had a practice run towin the van with some 35's on went ok but i felt that the 4.6 would be the go . I have 4.1 diffs at the moment.
    Drove with the splits on a while ago and the ute felt it would tear the bitumen up. So that's why I would like the 4.6 gear set.
    If I don't go for the 35's I reckon a front locker and shimmed lsd rear would be the go and of course a lot cheaper.
  11. #10
    Enjoying the trips macca's Avatar
    Oct 2010
    Old Bar, NSW
    13 Post(s)
    Quote Originally Posted by macca86 View Post
    High range 1st gear is too tall, add pulling a van even at 2 tonne with need to slip the clutch to get moving.
    Mine is on 33's and that is hassle enough getting moving on a uphill start. 35's will be worse. The transfer case reductions are great but only in low range half of the box, so no help on the highway.
    Macca
